My other ride is a C-130J
RNajarian's Avatar
Headlight Washer Pump
Regarding a headlight washer pump on a 1975 S, Can you use a regular Windshield washer pump Instead of the standard headlight washer pump?
I suspect volume and force of the water is an issue
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 11-08-2012, 11:16 AM
kodioneill's Avatar
No; you need what you thought, more pressure and volume.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-09-2012, 09:04 AM
Recreational Mechanic
Nickshu's Avatar
Above post is correct, the pump is special, high pressure, and uses a much larger diameter hose than the washer fluid system does.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 11-09-2012, 09:32 AM
djpateman's Avatar
Mine is probably larger than the fuel pump. About the same size as the wiper motor.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-09-2012, 12:35 PM
