MFI leak?
Hi guys,
Just pulled the engine to fix a bunch of annoying oil leaks. Worst one seems to be the left camshaft seal. Found this one at the back of the MFI pump. Any idea what it can be? Ed http://forums.pelicanparts.com/uploa...1352570977.jpg |
There should be a rubber cover over the opening above the gear.
Found the cover! That's it then?
As long as the rubber cover is not old and cracked. A new one will fit tight over the rotating plunger (rack) to hold in the oil.
Any one have a pic of the rubber cover referenced. I may have the same leak
The Bosch part number is: 1 410 508 008. Unfortunately the "Rack Cap" part is NLA except if you buy the complete MFI pump gasket kit.
http://forums.pelicanparts.com/uploa...1375977623.jpg http://forums.pelicanparts.com/uploa...1375977647.jpg http://forums.pelicanparts.com/uploa...1375977667.jpg |
Oil Leak
Thanks Mark!
Carlo |
While your in there you might want to change the clamp on the rubber hose for a Norma type that doesn't chew into the hose.
Reproduced Protective Cap
We have reproduced the cap. Inquiries about office@eisenbrandt.eu
http://www.eisenbrandt.eu/images/1410508008.JPG |
Joerg,
Holly mother of MFI...that is a pure money. |
Odds are your camshaft seal is OK, that missing cover on the rack access will dump a lot of oil down the back of the engine. I had the same issue, now one of my bar stools is missing a protective foot.
| All times are GMT -8. The time now is 11:50 PM. |
