Installing inner bearing rear wheel 930
I hope someone can help me with a bearing problem. I have removed the hub and the outer and inner race from the trailing arm. How do I install the inner bearing without proper tools. Can I install the outer bearing, inner and outer races and use the axel to pull the inner bearing onto the hub. I am thinking of freezing the hub and slightly warm the bearing and slide it on and use the center nut to pull them together?
I will be very happy for any answers.
Old 11-13-2012, 12:53 PM
Not an easy job. Especially with the arms on the car.
Here's a little light reading:
what I learned about 930 rear wheel bearing replacement
930 rear wheel bearing removal
Replacing Rear Wheel Bearing
930 Rear Wheel Bearing Stuff
Sir Tools Rear Wheel Bearing Tool
Rear wheel bearing removal tool kit!!
Ken
1986 930 2016 R1200RS
Old 11-13-2012, 01:02 PM
930 forum has several threads about dealing with rear wheel bearings. Warning they are a bit scary!
07 Exige S
Champagne on Beer Budget
HelmetHead's Avatar
Took me about 5 hours with the Sir tool master kit...Also, the master kit does not have all the necessary adapters to remove the races..GRRR!
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 11-13-2012, 01:07 PM
