-   -   Engine shroud refurbishing (http://forums.pelicanparts.com/porsche-911-technical-forum/716277-engine-shroud-refurbishing.html)
Eddyvdw 11-11-2012 12:59 PM
I pulled the engine and am in the middle of cleaning, resealing and refurbishing the lot.
Any suggestion to get the engine shroud as new? It's dirty and a bit cracked at the surface.
Searched a bit but most threads are about powder coating and blasting.
Thanks!
Ed
http://forums.pelicanparts.com/uploa...1352667501.jpg
http://forums.pelicanparts.com/uploa...1352667526.jpg
al lkosmal 11-11-2012 01:38 PM
shroud
Ed,
Mine looked like yours. I wet-sanded, then used rubbing compound...then a couple of coats of satin clear.
PS: I de-greased it 1st...probably using carb cleaner and a tooth brush.
http://forums.pelicanparts.com/uploa...1352669744.jpg
http://forums.pelicanparts.com/uploa...1352669760.jpg
http://forums.pelicanparts.com/uploa...1352669788.jpg
http://forums.pelicanparts.com/uploa...1352669832.jpg
regards,
al
fanaudical 11-11-2012 01:42 PM
No real good ideas here. I "reconditioned" mine but was not doing so in order to keep it looking original. Mine was in worse shape than yours and here's what I did (sorry, I don't have any pics):
- Wash/degrease thoroughly
- "Scruffed up" with 120 grit sandpaper
- Applied a coat of new fiberglass resin to try to arrest a bunch of cracking
- Painted inside flat black and painted outside with black wrinkle paint
fanaudical 11-11-2012 01:43 PM
Was typing mine while Al was typing his - I like Al's solution better!
Eddyvdw 11-11-2012 01:49 PM
Thanks guys!
Al, how did you refurbish the airhousing? Looks great!
Ed
Kidasters 11-11-2012 01:51 PM
I'd degrease it and find some high temp green paint and just paint it.
If you don't want to stay stock, there is a carbon fiber shroud out there that I think looks pretty good.
Rot 911 11-11-2012 02:36 PM
I would not paint that if you ever have thoughts of selling. Buyers of long hoods want originality.
maui44 11-11-2012 03:29 PM
Al, Yours look great.
Nice job.
al lkosmal 11-11-2012 04:55 PM
The fan and housing were de-greased and bead blasted.
regards,
Al
