My other ride is a C-130J
RNajarian's Avatar
1975 S Headlight Washer Wiring
Hi Gang,
Trying to sort out a mess the POs body guy did on my 1975S
Easy Question: What is the color of the wires going to the headlight washer pump. I suspect the ground is either brown or white with black stripe. What is the 12+ V
At the headlight washer switch on the dash the incoming wire is brown, the wire going out is white with a black stripe. The wires were soldered to the switch. Unusual to see that type of connection.
Can anyone verify the wires going to the pump?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 11-12-2012, 02:07 PM
frankc's Avatar
I can check the wiring on my '77 pump if that helps, but they may have changed from '75
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-12-2012, 05:08 PM
