Bumper questions and moldings
I have a 1985 911 Euro Cabrio and I noticed my bumpers have the black "shocks" on them that are very worn, and in most cases, cracked and split. How hard of a fix is this? I have not really seen a replacement online for that... Thanks
Old 11-21-2012, 11:54 AM
Josh D's Avatar
Are you talking about the accordian pieces that fill the gap between the bumper and the body?
Pelican sells OEM. I bought a set of four reproduction ones off ebay for under $100.
Not too hard to replace. Four nuts per piece.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 11-21-2012, 12:58 PM
donagain1's Avatar
I have the USA version of the same car. They are relatively easy to remove, bolting onto the bumper from the backside. You have to remove a piece of tin behind the bumper there in order to access the nuts. Where to source replacements I can only guess, specialty wreckers like Parts Heaven perhaps, though I've never looked to see if Pelican carries any. Unless the splits in yours are in exceedingly obvious places, I had good luck revitalizing the surface of mine using a run-of-the-mill dressing for black parts that I bought at a FLAPS.
Old 11-21-2012, 01:04 PM
