Champagne on Beer Budget
HelmetHead's Avatar
Coupe Restoration..Rear roof vents - plastic foam strip bleeding??
What are you guys doing to seal the rear cabin vents on your coupe restorations.?? Part #911-503-507-01 seems to be long ago NLA
With at least a dozen current full restorations going on amongst the Pelican brain trust...what have you used as a replacement or alternative. Photos always help
Thanks in advance!
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 11-13-2012, 07:57 AM
E Sully's Avatar
I used a piece of foam that was originally for window mount a/c units to seal the window gap. It stops water from getting in, but still allows air flow.
Ed
1973.5 T
Old 11-13-2012, 08:48 AM
Banned
RWebb's Avatar
This thread motivated me to look at mine... no foam found on my 6 owner 1973.5; instead, there is a hard black surface recessed ~ 1 cm back
I probed it with a toothbrush handle and it is indeed hard - maybe plastic or hard rubber.
Anybody know if P AG put foam back there in 1973.5 cars? Harry?
A PO did replace the headliner, so ya never know...
Old 11-13-2012, 09:16 AM
Diss Member
Quicksilver's Avatar
I just let it go the way of the dodo. I don't spray water that direction and I don't drive real fast backwards in the rain...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-13-2012, 10:17 AM
E Sully's Avatar
Vents above rear roof - foam replaced
Rear vents above window
Ed
1973.5 T
Old 11-13-2012, 02:18 PM
HelmetHead's Avatar
Thanks Ed, I didn't see the first thread in my search, and I like the idea of the open cell foam as that was what the factory used.
Einar
Old 11-14-2012, 05:30 AM
McMaster-Carr is your friend...I used 1"x1" open-cell, cut to length
Old 11-14-2012, 08:27 AM
E Sully's Avatar
I snaked a piece of electrical wire through the opening, then taped the foam to the end of the wire to pull it in.
Ed
1973.5 T
Old 11-14-2012, 08:41 AM
