I have two stripped studs in the oil strainer sump plate so the nuts won't tighten. Does anyone know the stud size and if Pelican Parts has them available??? My garage floor would be most grateful!!!
Thanks in advance I hate oil leaks!!!
WHITE 1983 911SC COUPE! |
M6 x 1.00 x 12 mm DIN 8.8
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thank you thank you thank you!!
You do not have permissi
Although you probably wouldn't do it because it really
is a backyard pinch fix, You can go to the hardware store and buy the bolt and cut off the head, trim it down and turn it into a stud with a little careful grinding and a thread file. Grade 8 need not apply.
hmmmmmm not a bad idea!
