-   -   Why is only my passenger taillight out? (http://forums.pelicanparts.com/porsche-911-technical-forum/716939-why-only-my-passenger-taillight-out.html)
Winter 07-05-2025 03:08 PM
Originally Posted by 86911tlcab (Post 7100475)
You can reach into the socket with a small tool and bend the two metal pieces toward you...I did the same thing and it worked fine. they will then press up against the light bulb..
I literally just did this “repair” this morning. I was attempting to figure out why my front rt. turn flasher wasn’t working, noticed that my rt. rear taillight was not illuminating, the bulb looked fine, but was loose and not contacting the metal tabs in the housing, pulled the tabs out with a small pick and now the taillight works as it should, as well as my front flasher.
It was nice to have the fix be so simple, and a good reminder to check that all bulbs are making correct contact in their housings before going deeper and pulling things apart.
zuch 07-05-2025 06:32 PM
Do the lights work with the hazard switch?
kevbo 07-06-2025 04:22 AM
Hi Zuch, yes the hazards work along with the brake lights. Just the right front and rear "marker" lights don't work. Thoughts?
Dpmulvan 07-06-2025 06:10 AM
Originally Posted by Hotwatermusic (Post 7092381)
My passenger side rear taillight is out--both parts, rear and side. Turn signal and brake lights work though. The bulb filament looks good though. What would cause just my passenger side rear tail light to be out? 1974 911
Thanks!
Canton police.
kevbo 07-06-2025 08:19 AM
Removed the headlight switch. This wiring concoction (thin red line trace) seems interesting for the right-side lighting... Thoughts other than calling the Canton police? :)http://forums.pelicanparts.com/uploa...1751814956.jpg
