Send a message via AIM to EPorsche
Megasquirt 3.0 Map
Anyone have a good MS2 or MS1 extra map?
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 11-14-2012, 06:18 PM
Wer bremst verliert
JohnJL's Avatar
Many are posted. You dont neet it to be ms1 or ms2 either, any manufacturer graph will help.
I've found the trick to getting started isnt even the map, its the cold start and idle settings.
Also you might post any other mods to the motor. Is it otherwise a stock 3.0? What injectors, intake and ignition?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-14-2012, 06:49 PM
I have MS1 and have been running it for some years. Thinking of switching to MS2 or MS1 extra where there are quite a bit more drop downs to input info. It is tat info that I need.
'81 911SC stock
Old 11-14-2012, 10:42 PM
I have some that are starting points (16x16) and fuel only. Not perfect as I have been chasing some other issues, and you'll need to be careful about things like injector profiles, but happy to send you something. I have MS2 on a stock 80 SC. I do have an idle control valve, but if you don't not sure it will matter if you are using the AAR.
PM me and I'll dig one up.
Also, are you using Tunerstudio? If you aren't, strongly suggest you use it. It is much easier to manage the complexity of the MS2 and above with Tunerstudio
Kinsley
1980 SC Targa - MS2, EDIS
Old 11-15-2012, 06:02 AM
I would rather be driving
jpnovak's Avatar
send me an email. I just got done tuning an 83SC with MS1-Extra code. I will share the file. It is running fuel only.
Old 11-15-2012, 10:36 AM
