Spark plug threads
Is applying anti-seize on spark plug threads a good idea? :confused:
Sure. Just a smidgeon on the threads.
Copper based is best
Just read somewhere on this forum yesterday that Porsche advised against it as it reduces conductivity thus decreasing the spark.
Personally I never use anti-seize on spark plugs, but it is a matter of personal preference. |
I use just a little Permatex Hi-temp copper-based anti-seize. Easy-peasy. Have noticed no ill effects on ignition. But I can see how that might be an issue if you use too much. Then again, copper's a pretty good electrical conductor . . . .
Well then "NEVERMIND" SNL :-P Tre Bien Monsuir!
Going to do my plugs tomorrow :-P |
Thanks, I was thinking a very little would not hurt.
However, I will follow the bulletin. Thanks again. |
damn, I just did my plugs....guess I'll wait until the next 15K checkup. Dry, indeed.
I use anti-seize on the threads but a miniscule amount. I've been doing it for many, many years on all the cars, including the 911s.
I GUARANTEE that if you use too much, the plug won't spark. Been there, done that. :rolleyes: angela |
Interesting comment in this month's Panorama Tech section. Guy having trouble getting a plug out and the moderator sez........use a bit of anti seize next time.
If you ask 10 people you will get 10 different opinions.:D
In the end it is what makes you comfortable that matters.;) |
This is a tech bulletin from NGK regarding anti-sieze. Spoiler alert - they say not to use it.
Well ngk is what I use, so I will make it so :P
You do not use anti-seize due to the plating on the spark plug threads.
The Porsche owners manual also says change the oil every 12,000 (or 15,000) miles and CASIS says shift at 2100rpm. I change (and shift) at 3,000. Lotsa choices. :D |
I will continue to use anti-seize. I also don't use plugs with any special coatings on the threads.
| All times are GMT -8. The time now is 10:34 PM. |
