-   -   What is that Up There under the Driver's Side Front Fender? (http://forums.pelicanparts.com/porsche-911-technical-forum/717208-what-up-there-under-drivers-side-front-fender.html)
scotricker 11-16-2012 08:23 AM
78 SC. I know the big piece is the windshield washer, so I can easily relocate that stuff. But it looks like there's something else up in there, too. Can I remove or relocate it? What is it? I am working on a second oil cooler over for that side.
Gordo2 11-16-2012 08:31 AM
Receiver/Dryer
If your car has or had air conditioning, it is the receiver dryer canister (line going into and out of a can shaped object).
If your a/c was removed incompletely, this part could still be there.
Gordo
Justin@Athens 11-16-2012 08:32 AM
I don't know alot about the early cars, but I know the late 80's cars have an evaporative system for ducting fuel vapor which has components in that area, as well as in the rear passenger side fender.
tshebib 11-16-2012 08:42 AM
Scot,
The other smaller tank is an expansion tank for fumes from the gas tank. The line eventually makes it's way back to the charcoal cannister in the back. I removed mine and just looped the line back to close the system. I tried to search for a better solution but came up empty.
http://forums.pelicanparts.com/uploa...1353084084.jpg
scotricker 11-16-2012 09:05 AM
That's It ! I'll do just that. Thanks for the pic. Now there will be space for cooler #2. :)
DRACO A5OG 11-16-2012 04:31 PM
Right there where the windshield wiper tank was.
