Cylinder head nuts tighten up 930 in what order
Hello looking for a picture, to know what order they tighten up in please.
Thanks for any help.
EVERY MILE IS A SMILE porsche930.myfreeforum.org |
criss-cross the center cylinder, then do the same on each end one.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Do this sequence, but do it in stages to keep everything even. Start with 5 ft/lbs, then go 15, and then final torque.
-Andy
72 Carrera RS replica, Spec 911 racer |
Happiest when Tinkering
Where did that torque pattern come from because it appears you are torquing the inside of both outer cylinders before you torque the outside instead of a criss cross pattern
Last edited by gsmith660; 11-19-2012 at 02:53 PM.. Reason: Because iPhone auto spell sucks sometimes |
Wayne's book explains the sequence read it if you can...
I always do the same sequence so I dont get lost. Center head, right head then left. I always go to the farthest nut for the next in sequence starting with the upper left on the head..
Initial torque and let set for a while and retorque to spec. Bruce |
Thank you.
That doesn't make it correct that sequence goes against all my nuclear mechanic background and experience.
That kinda looks like the torque pattern on a 350 head but that isn't 3 separate heads and there is a logical reason why you torque a 350 the way you do.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
