s_wilwerding's Avatar
911SC defrost dial
I just bought an '81 911SC - my first Porsche. The previous owner had somehow managed to break (it now spins freely) the defrost dial located on the console between the front seats. In some attempt to fix up the car, I would like to replace the dial. However, I cannot seem to find the appropriate part.
Can anyone help me? Has anyone else had this problem?
Thanks.
Old 06-17-2002, 08:40 AM
Senior Member
Jdub's Avatar
It may go deeper than a fresh dial. The dial activates a cable that opens or closes a vent under your car. That vent, when open, exhausts hot air to atmosphere. Closed, you get the hot air in the cabin.
If the dial won't move, *maybe* the cable(s) are frozen at the vent box? It would make sense to manually activate the vents to determine if you have frozen cables.
Then again, maybe the dial just broke! It can't hurt to have a consenting independent mech. put it on a lift for a six-pack and give you the benefit of their experience.
John
'78 Targa in Minerva Blue
Old 06-17-2002, 10:46 AM
Information Junky
island911's Avatar
Re: 911SC defrost dial
Originally posted by s_wilwerding
. . .the defrost dial located on the console between the front seats. . . .
Where? A, B or C ?
Old 06-17-2002, 11:31 AM
Senior Member
Jdub's Avatar
Island and '81:
Isn't this the dial facing up between the seats, where you might find the "old" hand-operated levers?
If not, forget everything I wrote above!!
John
Old 06-17-2002, 11:37 AM
It's even further back than shown in the picture. There's the hand brake and heater control on the floor and behind that, on the console between the seats (like where an armrest would be), there is a defrost dial. Is this something unique to the Euro models?
Thanks for all your help.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 06-17-2002, 12:05 PM
Information Junky
island911's Avatar
Originally posted by Jdub
. . .Isn't this the dial facing up between the seats, where you might find the "old" hand-operated levers?
John
Ah, right . . .the "climate control" box.
You guys with your plush cars.
Old 06-17-2002, 12:07 PM
steve911's Avatar
Defrost dial?
Are you sure its a defrost dial? On my '85, it is a 3 position switch for controlling the heater fan, not the defroster.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 06-17-2002, 12:47 PM
Senior Member
Jdub's Avatar
Hey buddy, you are talking to a window rollupping, heater lever pulling fool over here so show some respect!
Heck, even my valve gear clearances require manual updates...
Har har,
John
Old 06-17-2002, 12:50 PM
rfix'n's Avatar
I have the "plush" auto heat, if your dial just spins and there is no corresponding change in the red lever than your auto heat is broken. If this is the case, chances are someone pulled / pushed the red lever (a no no with auto heat) and broke the mechanism inside. Not sure if parts are available for the climate control box or if you have to purchase a whole new box. I think most people convert to manual heat when this happens.
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 06-17-2002, 01:18 PM
Bill Douglas's Avatar
Most of those things don't work. If you do want to have a go at getting it going pull the cover off and find exactly what is wrong. There are also little polyurathane ball in socket things that fall out plus the little motor may not go either. Also there is a temperature reader sensor by the rear view mirror that may not work either.
On my car, a '79SC, all of the above were knackered so I just use the levers. Much better.
I'm thinking off pulling the guts out of the heater dial box so I can cut a big hole in the top to use it as a coke can holder. Good idea?
Old 06-17-2002, 03:37 PM
Doug E's Avatar
I didn't know that control box was available in '81. On mine there are just levers.
BTW, welcome to the wonderful world of 911 ownership!
Doug
'81 SC Coupe
Old 06-17-2002, 06:59 PM
Team California
speeder's Avatar
The dial you are refering to is the optional automatic heating control that was available in 1981. I have it on my '82 SC. If dial spins freely, there is a SLIGHT chance that knob is stripped and can be replaced. Not sure, but even that might be a junk-yard only item, the climate-control is sold as a complete unit, dealer only, price including Porsche tax is approx. $1200.00.
The way to simply bypass it is to remove tiny bolt that connects heater lever, (with red knob), to auto-control. Then you can use lever manually as though auto-control was not there, only catch is that heater blower-fan in engine compartment is wired to auto-control, will not go on when you raise lever as it is supposed to. Fan is not really neccesary, but it does kick some extra ass when it's really cold or windows are fogged badly. If your auto-control is broken in the full-on position, (as mine is), and fan is not dis-connected it is probably fried anyways. Good luck.
Denis
Old 06-17-2002, 07:54 PM
