close up wheel well vents?
Any reason to not hammer close and seam seal the smugglers box vents in the wheel well area to prevent moisture and dirt from coming in the front compartment??
this
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
Bump
Fleabit peanut monkey
1981 911SC Targa |
You talking the floor pan holes?
1981 911SC Targa |
Bird. It's the word...
I don't think there would be an issue sealing the louvres...
John Forcier Current: 68L 2.0 Hotrod - build underway |
Yes there were there to vent the heater as I've read. Couldnt find anybody discussing it but it just seems like there is a lot of wind dust and moisture going up those things right next to a spinning tire.
There is also an exhaust pipe leaving the smugglers box under the car (at least on my 73)
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I have always thought they were there because of webasto heaters, but never understod it. The smuggler box must get plenty of air from around the steering shaft???
I'll probably seal up my vents, but I think I'll just put some silicone sealer from the inside.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Had to use Google Advanced Search to find this link. Grady Clay confirms they are for the Webasto. I ain't got them (the vents), hence my ignorance above. Check out post 24. Early S Torsion tube replacement begins
1981 911SC Targa |
