Transformation of 76 911S to 993 911GT
I joined about 1 year ago , but never formally introduced my self , My name is Helio, and this my 1976 911S - 993 911GT clone I have owned her for 21 years, When bought in 1990 ,It was just a plain jane 911S w/ 2.7. I was 22 years young , fist thing I did was widen the rear fenders , Carrera style , front valance and H5 head lights then up grade the susp to an 86 incld the brakes ,sway bars etc, followed by 1988 3.2 . then installed light weight fly wheel and clutch pkg, chip , cat bypass, K&N filter and a B&B muffler,
I mainly drag raced her, then I found PCA, I did some auto cross and DE's , Back in the day Cool Carbon pads where a good upgrade and ATE blue and BF-G's wow my lap times went down,
I now addicted to more performance in 1995 I saw a 993 911 GT2 fell in love with the style, I couldn't by the car, but I could trans form my 76 911S , what looked like an 86 Carrera by now. so in in the late summer 1996 I started and finished early spring 97
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 01-23-2012, 02:12 PM
My goal , well the 1995-96 911GT was 2850 pounds and 430 hp , the street version with 225 F and 285 R . I wanted to be lighter and more powerful and handle almost as good,
FRONT, B&B full width oil cooler, 993TT brakes w/ custom hats, brake bias adjuster, 22mm torsion bars, RSR Bielstien shocks, Tarrett mono ball shock tops and sway bays, Kinesis fully forged 245-40-17 ( out dated next set will be 18's speedlines)
REAR, Elephant racing 935 style spring plates ,RSR coil overs 500lbs , Custom valved 125/325, 965 3.6 rear brakes caliper 930 rooter , 315-30-17 Cut the torsion bar tube.
TRANS, G50-01 Patrick Motorsports strengthened bell housing ( I broke the 1st one)
8;32 R/P gives me 163 at 7300 rpm's ,KEP 600 lite, clutch pkg , stock fly wheel,G50 peddle assembly and axles.
1992 964 C2 turbo
Old 01-23-2012, 02:15 PM
ENGINE, ( I broke 2 motors using reconditioned parts, I learned my lesson) It started as 1989 930/66 ROW , the cases polished inside , boat tailed and shuffle pinned , New crank , new 3.3 OE PC's , Carrrillo Rods , ARP bolts, 3.3 heads polished and matched ,machined 1m to get 7.5 to1 comp, 964 cams, New valves , Assco Racing high rev springs and titanium retainers ( good for 8500 rpms)
IGNITION, Peterma Tune all in one no coil and 930/66 dizzy dual vac, timing set at 29 deg BTDC w/ hoses disconnected at 4000 rpms ,
INTAKE, stock intake ROW 930/66 CIS 320mil per min custom fuel head matching fuel lines, 009 injectors, 930/66 WUR 112 ( Cly's 2 and 5 set up to flow more fuel to make up for the extra air they get. I got pic's) K&N kit, Custom IC full width , 965 style BOV. Fuel pump 1 Bosch 044,same a GT2
1992 964 C2 turbo
Old 01-23-2012, 02:16 PM
TURBO , Turbonetics/Garret T4/T3 turbonetics 60-1 comp O trim ,hot side Garret dual scroll housing 84 AR , V band, 46m Tial wastegate 1.1 Bar spring
EXHAUST , Carrera heat exchangers ( with some modifications ) Borla race muffler
I also moved the moved the motor and trans forward 3/4 of an inch , the G50 mounted to a plate that is then mounted on a stock 915 trans mount, on different holes, the engine mount is bowed a little, 930 are set up at 38/62 balance , I now have 40/60
POWER , Dyno tested 428 FWHP and 490 tq at 4200 rpm's , On a cool day with 93 octane
1/4 mile 11.98 at 123 , 0 to 60 3.9 top speed 163 I get there in just over a half a mile.
1992 964 C2 turbo
Old 01-23-2012, 02:18 PM
AutoBahned
RWebb's Avatar
would it have ultimately been cheaper to buy a 993?
I got my photos out and scanned them , 65 0f them of the body work done to the car back in 1996, The car started as 1976 911S , I bought the in 1990, drove with some mods, then I decided to change it to 993 Carrera RS look with 3.2, in 1998 911GT with turbo motor G50 etc.
THE BODY KIT, 1996 A.I.R American International Racing 993 turbo, The body work was done by my friend who worked for N.A.S.A and axis to the best bonding agents , so no cracking, very strong stuff, the oil tank had to be modified to fit the rear bumper, RSR tail while it was a 3.2, The color is Comp yellow, with matching roll bar and seat backs , RSR carpet kit ,door panels and carbon fiber dash. At that time I did alot of track events , The looked good but missing the small details,
1998 the 911GT look and mod's , replaced the front bumper to the GT style, GT flairs and tail, also changed to a 993 hood ( notice the window washer of on the hood) 964 dual spring wipers, they are lower profile,
1992 964 C2 turbo
Old 01-23-2012, 02:20 PM
here's some pic's where it all started,a 1976 911S
1992 964 C2 turbo
Old 01-23-2012, 02:27 PM
yes it would of been cheaper to buy a 993 but not as fun,
1992 964 C2 turbo
Old 01-23-2012, 02:31 PM
At this point starting to see some progress,
1992 964 C2 turbo
Old 01-23-2012, 02:39 PM
home built paint booth,
1992 964 C2 turbo
Old 01-23-2012, 02:45 PM
Oh Haha's Avatar
Nice job!! A 993 GT2 is one of my dream rides and it looks like you did it right.
EDIT-I just saw your new wheels. Absolutely spot on!!
Pacific Blue
Wayne
Old 01-23-2012, 02:48 PM
now it starts to look like a 993
1992 964 C2 turbo
Old 01-23-2012, 02:51 PM
I enjoyed the 3.2 NA in the 993 RS trim for while , until I blew it up at willow,
1992 964 C2 turbo
Old 01-23-2012, 02:57 PM
time for the big HP power and the 911GT tail and later the flairs
1992 964 C2 turbo
Old 01-23-2012, 03:04 PM
I also changed the door window frames the 993 style and the rear quarter windows to 993 ones also and all the body seal where changed to 993 ones, at the rear bumper I also added the alum trim around the muffler tips like the factory , front grill , I also added the emergency front hood release cable , 993 head light release mech, 993 wiring harness for the lighting with relays, Porsche Lictronic head lights ,
In 2008 I married with 3 small kids not much time for track days, out went the roll bar and race seats in with plus carpet and sound deadening , RSA power seats, that works.
Heat, 993 upper and lower dash and 993 back seats, updated the seat belts to the top of the rear deck, 993 sun visors and 993 front hood release mech ( what a deference that made) The big big change was the instruments gauges, chrome 356 style bezels with LED lighting from Hollywood VDO, WOW
1992 964 C2 turbo
Old 01-23-2012, 03:12 PM
here's the motor , it has now 40,000 miles and just had a leak down done, I was bracing for bad news and to my surprise , 2 to 3% leak down on all cyl's WOW, I drag race , autocross and do DE's with her and drive her hard,
1992 964 C2 turbo
Old 01-23-2012, 03:21 PM
It took me 16 years to find these 911GT Speedlines to finish the look that I wanted, I just got them in this week , I mount one for the test fit waiting for warmer weather now for the rest, my car will like this blue 911GT but in yellow
1992 964 C2 turbo
Old 01-23-2012, 03:30 PM
privatepang's Avatar
looks great! Thx for sharing
1975 Aubergine 911S - Barney
"When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson
Old 01-23-2012, 04:00 PM
lonewolf's Avatar
sure brings back memories. I had twin fans on the side door and a waterfall on screen door leading into the house.
Nice build. Everyone has to do one at least once.
Ya ,it may cost you more but it's the fun that counts,the vision of the finished product,and the joy and pride of the first shakedown drive.
I bet you know every square MM of that car. Well done.
Old 01-23-2012, 04:04 PM
After 21 years with her,I do know every mm of her
1992 964 C2 turbo
Old 01-23-2012, 04:32 PM
