GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Oblong slots above rear window?
I have a question..... The oblong slots above the rear window. What were they intended for? Does it just scavenge interior air? From the factory there was a piece of foam placed in between the roof and the header. My guess is the foam was a way to damn and absorb moisture that may enter? On my car that foam has deterioated and has literally vanished. So, if i hold a flashlight aimed at the slots from the outside, I can see the light through the perforations in the headliner. And when a 65-94 911 is restored, is that piece of foam crucial? And is jute (insulation), still added above the headliner? Anybody
It changes from time to time.....
Old 11-20-2012, 03:56 PM
I left the foam out. To have some air exiting from the cabin, seems to me to be desirable.
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 11-20-2012, 04:20 PM
Diss Member
Quicksilver's Avatar
Yes it is just part of the ventilation. The headliner is perforated to go with it. When washing the car avoid spraying up in it and don't drive more then 60mph in reverse when it is raining.
(Ok, I made that last part up...)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-20-2012, 05:11 PM
jsveb's Avatar
I installed some 3m spunge-type material of the same texture as the original stuff.
Old 11-20-2012, 05:24 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
LoL!!!! 60mph in reverse
Thanks for the replies! I appreciate it!
Old 11-20-2012, 05:40 PM
E Sully's Avatar
Takes a little bit of time, not a difficult job, cost is small. I like anything that will keep moisture out of my car.
Coupe Restoration..Rear roof vents - plastic foam strip bleeding??
Ed
1973.5 T
Old 11-21-2012, 05:55 AM
Banned
I laughed at that, too.
Old 11-21-2012, 08:36 AM
It's not crucial... but you should put it in to keep from damaging the headliner when washing car, driving in rain, etc.
Old 11-21-2012, 11:04 AM
Reiver
Reiver's Avatar
there was a DIY recently on this....2.5 in closed or open cell foam strips pushed into the slots from the back, no access issue thru the headliner.
Old 11-21-2012, 11:07 AM
mca mca is offline
mca's Avatar
For a couple of years now I've felt like exterior noise around the rear was way too loud. As if I had a window open. I chalked it up to a crusty rear window seal.
Last week I determined that I was hearing exterior noise through the sunroof zipper area of my headliner. Guessing that I'm missing some foam.
Old 11-21-2012, 01:44 PM
Go-Kart Mozart
JAR0023's Avatar
Picked up my car this spring. Always wondered why that Peterbuilt behind me at the red light sounded like it was in the car with me. Took a while but a little research here and I figured out the missing foam bit. I went to the Home Despot and looked around the 'roll of foam in a bag' section. I found my solution from Frost King. Listed as window A/C seal or similar. Anyway it was $2 for a 40"x1.5"x1.5" strip of open cell foam without any adhesive.
I carefully unzipped the headliner then removed the two fiberboard panels to gain access to the area from the back side. Once inside the h/l you can see that from the slots going forward there is a shelf and then a vertical section of metal with a small gap between the vertical and the roof. Just enough room to squeeze the foam and push it over into the channel with your fingers.
I had to use two pieces because I didn't feel like pulling the sunroof motor. There is a 'seam' in the middle of the car but no one but me knows it's there. Start in the middle and work outwards. When you get to the edge just trim the foam with scissors. Once in the channel the foam will expand to fill the area.
There is a little difference in sound, but it's not night and day. I drive my car in the rain and like not having to worry so much when washing the car.
-J
Here's a couple of photos.
Old 11-21-2012, 02:21 PM
What a coincidence. We were just talking about this today.
'Rear vents above window'
1975 911S Peru Red
Old 11-21-2012, 02:59 PM
