-   -   What's the 1st year for the Galvanized body 911/930?? (http://forums.pelicanparts.com/porsche-911-technical-forum/71818-whats-1st-year-galvanized-body-911-930-a.html)
Turbodrvn 06-18-2002 11:00 AM
Just curious about when the 1st year of the galvanized Porsche 911/930 body was? Was is 1976?? 77? 78?
thanks in advance.
stlrj 06-18-2002 11:08 AM
1976 for the 911. How do I know? I bought a 75 from the midwest that made me wish it had the galvenizing. I know I'll never make that mistake again.:eek:
Cheers,
Joe
ras911 06-18-2002 11:10 AM
1976!!
GIBSON 06-18-2002 11:44 AM
Galvanizing was phased in with 911's. It actually starter earlier than 1976 but was only used on certain panels. '76 was the first year for a completely treated car.
lin7310948 06-18-2002 01:20 PM
I have a 1975 Turbo and I have not found any galvanized panels but sure have located lots of rust. Unless vehicle has been in sunny climes or well taken care of, suspect rust and sometimes major.
Oldporsche 06-18-2002 02:31 PM
This is actually sort of a trick question.
It depended upon the year and body style. Coupe/Targa.
There is a diagram in the factory repair manual that outlines the years and parts of the car involved.
Safe to say parts of the '76 and all of the '77.
Good luck,
David Duffield
steve rush 06-18-2002 05:56 PM
what years
Also for example one 1976 912e is not coated but, some of them are.
GIBSON 06-18-2002 06:58 PM
Porsche started experimenting with rust-proofing in 1967 when they produced 3 911's made of polished, unpainted stainless steel. They were driven for thousands of miles, one still remains.
Obviously, the costs were prohibitive.
Porsche started galvanizing the wheel arches and pans on the D-series cars in the summer of 1970. It added 70DM to the cost of each car.
In 1976 Porsche started galvanizing the entire car for the I series cars. The only part that was not treated was the coupe roof. The treatment was actually a Zinc coating applied in a 500C immersion bath. Porsche began offering the 6 year warranty against rust at this point. They had to use different welding procedures and protect workers against the nasty vapors which the zinc can give off.
I don't know why I can remember this stuff but forget my wife's birthday.
Turbodrvn 06-18-2002 07:23 PM
oh oh......I'm hearing mixed messages here.
I'm about to purchase a beautiful 1976 Porsche 930 (Carrera Turbo coupe with steel flares) and was curious if it had a galvanized body.
GIBSON 06-18-2002 07:41 PM
If the car is a '76 911Turbo and there is no rust now, buy the car, you'll be fine. If it's got steel flares welded on and you don't now who did the welding, you can't be sure if the metal was treated properly before and after welding to insure that it won't rust.
Good body shops know how to treat bare metal so that the potential for rust is minimized.
Even a galvanized car which has bee stripped to bare metal and not properly treated will rust. The zinc coating was 40 microns on the heaviest rust areas and 20 microns on less rust-prone spots so it's possible to go right through that when stripping a car for repaint.
IMHO, if you like the car and have inspected it carefully for rust with good results, buy it and keep it protected.
tazzieman 08-18-2011 02:53 AM
I just came across this in Paul Frere's 911 storybook. Does anyone know the current resting place of this SS 911 , and are there any pix?
My ultimate 911 to suit my circumstance is a SS longhood in rally spec with some outlaw touches. Somehow I think that will remain in fantasyland :)
IROC 08-18-2011 03:21 AM
My '76 was built in December of 1975 and it appears to be fully galvanized.
One data point...
Bill Verburg 08-18-2011 04:34 AM
Galvanized steel was used for floor and inner panels from MY'71
outer panels of Thyssen steel were used from My'76, early '76 coupes were all Thyssen steel except for the roof but by the end of production the roofs were also Thyssen
Thyssen steel is double galvanized steel which is appropriate for outer finished body panels as opposed to simple cold galvanizing used on the inner panels.
the zinc in the galvanized panels added ~10kg to the cars weight
the '76 cars has a 6yr rust warranty which was raised to7yrs in '81 and again to 10yrs in'86
The famous picture of the 3 unpainted cars was 3 My '76 galvanized/Thyssen steel cars but there were also 3 experimental fully galvanized cars built in '67, the outer panels were polished but not painted or sealed in any other way.
from '72 ss steel was used for exhaust/heat exchangers and oil tank
Tippy 08-18-2011 07:08 AM
My '87 has rust popping up at the drain holes behind the rear glass.
So much for galvanizing.....
tcar 08-18-2011 08:23 AM
One data point...
Yup...
The '76 model year started in September, '75. September thru August is the MY.
JFairman 08-18-2011 09:11 AM
They started galvanizing the floorpan panels only for the 1974 model year, then starting with the 1976 models the whole chassis was dipped and galvanized.
Some welder fabricators hate welding galvanized steel because it spits while welding it.
Flat6pac 08-18-2011 09:17 AM
All the early turbos have welded flares, the factory didnt start stamping the quarters and fenders with the turbo flares until the early 80s.
I remember the 76 cars with the paint coming off the galvanization in sheets...
Bruce
Mikey83835 08-18-2011 09:28 AM
Keep them away from road salt and such as the galvanizing is far from being a cure-all, remember the factory only guaranteed them against rust for 6-10 years, lots of rust had to be cut out of this car:(;
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
