-   -   MAF sensor need ID (http://forums.pelicanparts.com/porsche-911-technical-forum/718212-maf-sensor-need-id.html)
vinyl_tien 11-21-2012 07:25 AM
MAF sensor need ID
I got this after mark MAF sensor from my friend's 964, but he lost chips, Can I use it on my 3.2? Where can I get new chip? Need you guys help.
PS. THE MAF Sensor is look like lower picture
Many thank!!
http://forums.pelicanparts.com/uploa...1353515095.jpg
http://forums.pelicanparts.com/uploa...1353515137.jpg
Tippy 11-21-2012 10:02 AM
That looks like the brand Authority IIRC?
I know the 964 AFM is the same as the C3.2 but that is comparing apples to oranges.
It should work as long as the chip is for a 3.2.
tratza 11-21-2012 12:18 PM
It looks a lot like the Autothority unit that I have but the control box is different. I'm guessing Steve Wong could modify a new chip for it. The stock 3.2 ECU chip will work but not very well. Let me know if you want a picture for comparison.
vinyl_tien 11-22-2012 04:59 AM
Thanks Tippy and tratza.
Hi tratza, can you post your Autothority MAF picture for me? many thanks!
By the way, where can I get Autothority chip?
tratza 11-22-2012 07:13 AM
Now that I look closer the controller looks the same just a different label. I think AutoThority closed shop. Check with Performance since they used to handle them. Mine is about 20 years old. The only problem I had was about 15 years ago when the potentiometer started giving me problems. Cost only $90 to replace. Very happy with it.http://forums.pelicanparts.com/uploa...1353600787.jpg
vinyl_tien 11-22-2012 09:20 PM
Hi tratza
Thanks a lot, can I ask where do you replace them? I think I might use them in my 3.2.
appreciate!
tratza 11-23-2012 07:38 AM
Good question. I did a search and didn't come up with anything. I don't think its a part you need to keep in the garage. Mine lasted a long time and it was probably the Texas heat that did it in. I'd check with our host and maybe a garage that has race experience.
