-   -   Does EVERYONE have one of these wired under the dash? (http://forums.pelicanparts.com/porsche-911-technical-forum/718544-does-everyone-have-one-these-wired-under-dash.html)
kohho 11-22-2012 02:08 PM
Hi folks,
I'm about to remove whatever this is but thought I'd check here first to make sure this isn't a Porsche wired-in device.
There are 3 wires coming off of it. The red wire appears to be connected to 12V near the ignition wiring. The 2 black wires go to the headlight switch and attach to 58L and 58R.
Thanks!http://forums.pelicanparts.com/uploa...1353625624.jpg
DRACO A5OG 11-22-2012 02:10 PM
Nope not on my 3.2 :-( definitely not OEM. Does it do anything?
GH85Carrera 11-22-2012 02:13 PM
I would GUESS it turns on the fog lights without the headlights. A lot of folks did that "back in the day" because they figured it looked cool to drive with just the fog lights on.
DRACO A5OG 11-22-2012 02:16 PM
Hey, I resemble that statement :P, mine are switched to turn on with the fog switch without the running markers, running markers are just too cool for this old guy :D
It really helped in the turkey run today, it was the fastest run I have ever joined, damn youngsters :P
86 911 Targa 11-22-2012 02:19 PM
Fog lights.
If it is for fog lights, here's a cleaner way:
http://forums.pelicanparts.com/uploa...1353626324.jpg
http://forums.pelicanparts.com/uploa...1353626346.jpg
Good luck,
Gerry
DRACO A5OG 11-22-2012 02:22 PM
^^^ that is what I did thanks to Dr Gerry :D Happy Thanksgiving!
kohho 11-22-2012 03:03 PM
Good question - I haven't actually tested it. There was such a jumble of wires under there I just decided to clean everything up and get things back to stock. Interestingly - the thing that got me going on all of this is that my fog lights didn't work. They came on as running lights but would not work under the control of the fog light switch.
I'm taking it out - thanks everyone.
Arne2 11-22-2012 04:27 PM
Another possibility is that it might be a "lights-on" warning module.
SLR 11-22-2012 11:07 PM
Speaker size?
I'm perplexed?
I did a search and found nothing. I need to replace
the sound system in my 85 911 and want to know the sizes of the door and rear speakers. I know the rear shelf one's are a bit tricky but the door one's look pretty standard. I don't need a big flash kit as I don't use it much nor can I afford to spend a lot.
thanks Steve.
nineball 11-23-2012 07:13 AM
6.5" should fit without a problem.
kohho 11-23-2012 08:08 AM
That's a possibility. Does your car beep when you leave the lights on? I think mine does for a few seconds- i'll test that.
