RETIRED
Looking for a bulk supplier of Heater hose....still
All the places I can find are Aviation suppliers and they want a minimum order of 10-20 feet......
SCAT or SCEET is the what it's called....SCAT is single walled and SCEET is double walled.....anyways, when VWs were still air cooled the bug and dune buggy shops all had them in stock in rolls. Now that all those stores are closed, the supply is either in short 18 inch lengths or have to buy from the Aviation Supply shops online..... Anyone have a connection or want to do a group buy? 8-10 a foot is Fuch'n rediculous....especially when you gotta buy 10-20 feet..... I'm looking at 2.5 inch and 3 inch to plumb my 3.6 Heat Exchangers... TIA
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
911-87 mit der 3.6 V-Ram und alles spaß |
Senior Advisor
Also try marine 60mm heater hose.
08 Cayenne Turbo |
Last time(a couple months ago) I was at Aircraft Spruce in Corona they didn't have a minimum length requirement for their SCAT tube.
SCAT AIRCRAFT DUCTING from Aircraft Spruce
1973 911T | Four owner car | My stewardship (2008-Present) 1972 VW Super Beetle | Two owner car always in the family | Gone, but not forgotten |
RETIRED
Hmmmm, Sure Marine Service, Inc. * Since 1972 * Marine Heating, Air Conditioning, and Galley Equipment It's not SCAT but it's the type used in the old school VWs that I'm used to.
These guys seem to be pretty reasonable. 60mm for the HEs to the bulkheads and the 3 inch for the blower to the HEs..... Thanks for the suggestions.... Last edited by Joe Bob; 10-18-2010 at 11:33 PM.. |
How much do you need??? I have about 7' left (I think, but a lot).
EDIT: It is about 7' and 2.5' ID. SCEET.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 10-18-2010 at 11:41 PM.. |
RETIRED
Cool, ya gotta PM.
Ya got one back.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
J.B. -
I buy that type of tubing from my local small airport maintenance shop. They will sell to me by the foot. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
I went with Racer Parts Wholesale, they were MUCH cheaper than the others I found:
Thermoid High-Temp Ducting I know it's not exactly what you're looking for, but it's an option for those interested in buying a full length.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
aircraft spruce. i just get the 12ft length for around $90. they sell smaller lengths too.
http://www.aircraftspruce.com/catalog/appages/scat.php
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-19-2010 at 09:37 AM.. |
Administrator
I just got the pieces for my car. I've got some existing 2" ducting up by the rear seat. And I knew I needed 3" ducting to wrap around the exits from the exchangers. So I got 5' of 3" Webasto 'High Temperature Ducting' from a place called Sure Marine Service in Seattle. It was $25.
![]() Then I got a pair of 3" to 2" reducers through Amazon. They'll let me mate the two together. ![]() They were $6 each. It bugs me to pay $37 for all this stuff, but what are you going to do? I'm putting in new axles next week and I figured that would be a great time to do the ducting. I'll post how it works.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
abides.
Be sure to secure those fittings well. I was using a plastic Y to route air into the heat exchangers, and twice now the hoses have slipped off letting the Y melt on the exhaust.
Graham 1984 Carrera Targa |
Pegasus racing is yet another internet source for this stuff.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
For anyone who has used this stuff in all it's variants (SCAT, CAT, SCEET, CEET):
Can it be slipped and clamped over an ellipse/oval? Just using 5" dia. ducting and at most a 3:2 aspect ratio. Nothing too crazy. I just don't know how flexible they are this way. I don't have enough real estate to use a round profile through a bulkhead. Nor do I have enough to do two smaller round sections. Any help would be appreciated. Thanks in advance. ![]() ![]() (borrowed from the Aircraft Spruce website) Tim K |
Administrator
Yes, 3" tubing will fit over the oval exit port from the heat exchangers. I used an ordinary hose clamp.
![]() ![]() I used a reducer to my existing heater tubes. My mistake was to assume they were 2". They're actually 2.5". So I just kinked it shut. ![]() It's nice to have heat. Or at least it will be nice, once Los Angeles' weather gets back in line with the calendar. Right now it's 96°.
Thanks guys,
I'm hoping I don't have to remove the wire. Especially if the ducting has an inner liner. We'll see. Tim K |
Josh 85 M491 Coupe - "Fat Bastard" |
