seat belt lock out relay on a 74 911
I would like to know where the seatbelt lock out relay is located in a 1974 911.
I would also like to bypass this relay and would appreciate tips as to how to do it.
Old 12-04-2012, 01:19 AM
Make My Day
wowzer911's Avatar
I think it's under the passenger seat. If you pull it you'll have to figure out what wires to connect together to complete the circuit.
74 911S Targa ROW
Building Designer/Business Owner
Old 12-04-2012, 03:38 PM
connect the two 50 wires, or C and 50 if i remember right.
206 637 4071
Old 12-04-2012, 06:53 PM
ok thanks!
Old 12-06-2012, 01:49 AM
kodioneill's Avatar
I'm not sure if this is what John meant but under the driver seat there's a set of wires that come from the seat pad pressure switch pull the seat wires out of the plastic connectors and connect the two wires that come out from under the rug.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-07-2012, 11:48 AM
74 911 Targa
pond scraper's Avatar
I found my relay in the trunk behind the air blower hoses on drivers side. Way up behind the dash
74 911 targa.
Old 12-07-2012, 12:42 PM
cut off relay
thanks for all the helpfull info!
is there an ignition cutoff switch too?
you see, I am able to crank the engine but there is no spark.
Old 12-08-2012, 10:39 AM
cut off relay
Old 12-08-2012, 11:16 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Regarding seat belts - can you just stick a clasp into the receptacle? I see them on Ebay and they are appear inexpensive. Under $10. Most are from China so prepare for a 10 day shipping window.
Porsche 911 seat belt clasp | eBay
Not sure if there is an ignition cutoff associated with seatbelt system. I would suspect not.
I would search on basic trouble shooting threads for no spark. Mine used to not crank at all when my aftermarket alarm would screw up. Dash lights would come on but no starter engagement. If you do have an alarm it may be worth seeing where it is tied in to kill the car.
1981 911SC Targa
Old 12-08-2012, 11:44 AM
no ignition cutoff.
206 637 4071
Old 12-08-2012, 02:08 PM
