-   -   How do you adjust the hand brake light switch? Also,where is it? (http://forums.pelicanparts.com/porsche-911-technical-forum/71914-how-do-you-adjust-hand-brake-light-switch-also-where.html)
thebondman 06-19-2002 10:22 AM
I have been having problems with the hand brake moving slightly and the "Brake" light coming on. I move the handle a little and the light goes out. I now have the cover off. Can someone give me some insight on what to adjust so the light goes off properly. Thanks,
BILLSmileWavy
P.S. HURRY, I'm putting in different seats.
Jdub 06-19-2002 10:39 AM
You should see a small screw on the side of the twin heater lever assembly and a slot in which the switch can move. I used a dime to turn the screw as there is very little room for a screwdriver. Loosen the screw, put the brake at its natural "off" rest point, and then (with ignition on) move the switch until it just goes out. Tighten down and test again.
John
thebondman 06-19-2002 01:12 PM
Works great, thanks.
BILL
