Window Frame Bracket, Early 911
I'm finally installing the window on my '73 911 coupe. I bought the car painted but in pieces and the car is missing alot of the original hardware.
It appears that I need a small bracket at the base of one of the tracks on the window frame that would connect the frame to the door. The Porsche diagram is not real specific. Any help would be much appreciated. Thanks, |
Hopefully I did this right. This is a picture of the window frame when I had it apart. Hopes this helps. This from my 76.http://forums.pelicanparts.com/uploa...1353913310.jpg
Is there a small bracket that connects the center rail to the door at the bottom?
Yes email and i will send you one
Lorne m. |
| All times are GMT -8. The time now is 05:54 AM. |
