LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
BRAIDusa's Avatar
Anyone have a cheap(er) fix for this? OE part is $165!
image by Team Illuminata Motorsport, on Flickr
Paul Eddleston
BRAID Wheels USA
The last Porsche Wheels You'll Ever Need
http://www.pelicanparts.com/catalog/SuperCat/0812/POR_0812_BDYWHL_pg3.htm#item11
Old 07-19-2017, 04:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #361 (permalink)
Porsche 935's Avatar
I cut the metal crimp off and replaced with a piece of hose and 2 clamps.
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 07-19-2017, 06:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #362 (permalink)
BRAIDusa's Avatar
but the hose is a reducer. Did you use straight hose?
Paul Eddleston
BRAID Wheels USA
Old 07-19-2017, 07:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #363 (permalink)
BRAIDusa's Avatar
The 911ís engine is back together. First we painted the valve covers red because racecar.
Then our cleaned and tested fuel injectors arrived from Cruzin Performance.
We repainted all the tinware
Then replaced the intake manifold connector with a silicone one from Vibrant.
We took advantage of the open engine bay to install some Sparco hood pins
Then our new intake gaskets arrived for TRE Motorsports
And a new engine cross member from Rennline
Munks Motors rebuilt all our fuel lines with Aeroquipe hoses
And Wevo sent us some performance engine mounts.
Finally we slapped the engine back in and took it for a drive but not before replacing the rear anti roll bar drop links.
The result of all this effort? The engine starts easily now and goes straight to fast idle then settles down to a smooth 850 rpm. No popping and bucking anymore and it pulls a lot smoother too.
https://youtu.be/TWqeISHUiaM
Paul Eddleston
BRAID Wheels USA
Old 08-16-2017, 08:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #364 (permalink)
Looks great! I know it's too late, but for the hose pictured above I put a double layer of heat shrink over mine. Mine hadn't failed though, just showed some small surface imperfections. Got the heat shrink tip from someone on this board.
Did you actually refurb the air meter flapper? My car will surge a bit when going from 0% to 5% throttle but is great everywhere else, which seems like the correct symptom for the flapper.
Matt - 84 Carrera
Old 08-16-2017, 09:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #365 (permalink)
BRAIDusa's Avatar
Are you referring to the hose that was split? That was repaired with heat shrink.
I replaced my flapper with a refurbed unit. Munks have the old for assement and possible refurb but all is smooth now.
Paul Eddleston
BRAID Wheels USA
Old 08-16-2017, 09:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #366 (permalink)
BRAIDusa's Avatar
We are pleased to report that the Carrera RX is now running very well indeed and we have been enjoying the car a lot visiting several cars and coffee events including an impromtu dash 200 miles up north to vist our 83 UR Quattro build at Cherry Classic Cars after our van blew a turbo hose.
We also attended the Woodward Dream Cruise and the Detroit Car week with the car.
Meantime we fabbed up a gauge pod to house the AFR gauge connected to the wide band o2 sensor we had installed while the engine was out.
This week we are dragging the car up to Empire, Michigan where it will once again be functioning as the course opening car. Maybe see you up there?
Paul Eddleston
BRAID Wheels USA
Old 09-11-2017, 02:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #367 (permalink)
BRAIDusa's Avatar
It's been a busy few weeks for the CarreraRX. A couple of car shows, pace car duties and even a race!
First up was pace car duty at the Empire Hill Climb in Northern Michigan. Normally we get to run a few parade laps up the hill but due to time constraints caused by the number of entries fun was restricted to escorting the cars from down town to the base of the hill. This is necessary as most of the cars are not street legal but need to use public roads from staging to the start. There were plenty of interesting cars on display too:
The following weekend was our (now seemingly) once a year RallyCross event with the Detroit region SCCA. As these were only a few days apart we let the CarreraRX sleepin the trailer.
Made some new friends and got the car nice and dirty.
https://youtu.be/MPNEwy0ah5w
Last weekend's adventure was to the car show held as part of the Speed Ring festival at M1 Concourse. At just over a mile from our shop we really couldn't miss this one. The event was primarily a Time Attack weekend but we did come away with two awards for looking pretty while stationary.
The car is resting for a couple of weeks in preparation for posing about at the Lake Superior Performance Rally (LSPR) in the Upper Peninsula of Michigan where it will get to meet non-other then Hannu Mikola! Should be fun.
Paul Eddleston
BRAID Wheels USA
Old 10-06-2017, 07:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #368 (permalink)
Why just 'posing about' at the rally? No class for the car? That'd be a shame and difficult to be there with such a fun car and not be able to run her.
Old 10-06-2017, 10:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #369 (permalink)
BRAIDusa's Avatar
Sorry, which event are you referring to? We didn't go to a rally. Went to a hill climb but the car would need a bit too much work to be legal for that plus we used to get to drive up the hill at ~90% which was plenty. Did not know that would not be possible this time.
We probably could have run the time attack but it was a two day event and we have a lot on our plate right now. Even the show as a stretch.
We did run the RallyCross though
Paul Eddleston
BRAID Wheels USA
Old 10-07-2017, 06:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #370 (permalink)
BRAIDusa's Avatar
RALLY LEGEND MEETS RALLY LEGEND
No, the guy on the left met the CarreraRX.
Last weekend we made our annual pilgrimage to the Lake Superior Performance Rally to hang out with our Group B rally car mates only this year there was a special treat laid on my the Guys from Dirtfish Rally School in the form of one Hannu Mikkola. Hannu was one of the first works Audi Quattro drivers and a true motorsport legend. Dirtfish also brought with them a replica of the MK2 Escort Hannu drove in Europe and a pristine Audi Sport Quattro. Hannu drove the Audi with us on Thursday up and back down the Keweenaw Peninsula then drove the Escort during shakedow, a couple of stages as course opener and then, again with us in the super special last stage in downtown Houghton.
There is a Flickr album documenting this occasion here but here are a few appetizers:
Paul Eddleston
BRAID Wheels USA
Old 10-27-2017, 01:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #371 (permalink)
BRAIDusa's Avatar
Can't believe it's been so long since our last update. So much has gone by, like: it's another year now! So what have we been upto since we got back from LSPR? Well:
We replaced the door seals then took out the rear window and resealed it with a new gasket.
No rust, thankfully.
Then we added a map light for an upcoming TSD rally.
Replaced the voltage regulator on the altenator and the fan belt.
Then had fun doing the TSD rally which really didn't go very as we set our clock 17 minutes off so were consistently 17 minutes early at every control. We did set fastest time of day though LOL. Our spot lights also packed up as soon as we turned them on. Still, we had fun!
We also did a RallyCross. That's two in one year! It didn't produce any great pictures (or results) but some in car video.
https://youtu.be/PuWtzustB9k
What's next for the car? Well, we are definately taking it up to Sno*Drift rally again at the end of the month and, due to the rather frigid weather we've been having here lately, there might be one or two ice races on the cards. We've got a door rattle to chase doen and a rain leak from the front end to diagnose. We also just received our heater blower backdate parts but that might wait for warmer temperatures just in case it sucks. Stay tuned (subscribe).
Paul Eddleston
BRAID Wheels USA
Old 01-06-2018, 01:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #372 (permalink)
Garen's Avatar
Nice. You took your motor out and put it back in way faster than my adventure...
The car looks great! Need to drop by and see you one of these days.
Mine's ALMOST back, just need to wire it up. But it's frigid in the garage, so maybe another couple of weeks before I get busy with it. Cold enough to make me take your BRAIDs and new NT01s to the basement!
Garen (87 930 track rat)
Old 01-06-2018, 05:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #373 (permalink)
BRAIDusa's Avatar
I've taken it oout three times since you started LOL.
It's going to be 50F this week. Get it finished.
Paul Eddleston
BRAID Wheels USA
Old 01-07-2018, 04:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #374 (permalink)
BRAIDusa's Avatar
The end of January saw our annual pilgrimage to the Sno*Drift Rally about 4 hours north of us in Atlanta, Michigan. Despite the name This particular Atlanta normally offers frigid temperatures and lots of snow but this more resembled its warmer namesake to the south. Much of the snow had melted and refrozen during the preceeding week making the roads an giant, elongated ice rink. Still, as we were only displaying our wares and the 911 it was not of much consequence to us, the warmer temperatures making it that much less uncomfortable standing around.
Here are some pictures from our weekend.
Untitled by Team Illuminata Motorsport, on Flickr
Paul Eddleston
BRAID Wheels USA
Old 02-11-2018, 05:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #375 (permalink)
