Idle Srew and Air Mixture Screw Setting
Okay guys,
For my '84 3.2L engine where would I set the idle speed screw and the air mixture screw as a best guess if I won't to clean out bth passage ways. I would think there is sort of a close ballpark point that you would start at and then adjust from there to fine tune. I may be wrong here on this or it may only be applicable to do the idle speed screw screw and leave the air mixture screw alone.
Dan O - (s)hit it still won't run
PS I got it to run last night for about 3 minutes by holding my hand over the air box snorkel and blocking some of the air flow in. This worked only if I bypass the air mixture by jumping the b to c socket. What's this mean you say, I have no F'n idea. I can't find any leaks in the connections etc so I'm guessing I still have some oil clogging the air mixture or idle speed passages or some component died. If I can't figure it out by Sunday it goes to the shop on Monday.
Old 06-20-2002, 06:41 AM
I don't know how these systems measure or meter air flow but I would assume there is some type of heated surface mass air flow sensor downstream of the air filter but before the fuel injectors. Could such a sensor be coated with oil and therefore not measuring air flow correctly? Perhaps finding and then cleaning or replacing this sensor should be considered. Cheeers, Jim
Old 06-20-2002, 07:39 AM
APKhaos's Avatar
Like your determination Dan - you are going to WILL this thing right!!
OK, it starts with the idle valve bypassed, but hardly runs.
You got it to run by reducing air in - by blocking off the inlet of the airflow meter.
So....don't touch the setting yet - all they do is bleed more air around the meter, which won;t help with the symptoms you report.
Have you checked resistance of the airflow meter?? The 3.2 DME uses a spring loaded barn door [which probably got bathed in oil when things first went wrong]. Check that the door moves freely - it should be closed normally. You are looking for smooth motion - no stickyness. Movement of the barn door drives a variable resistor [its under the black plastic cover on the AFM]. You should check that the resistance is correct, adn changes smoothly over the range of motion of the door
- use your tester on ohms setting
- remove the connector
- there are five pins, numbered from L to R
- measure between pins 2 & 3
Should be smooth across the range of motion.
It should be really smooth to move, and should return to the fully closed position under its own steam.
Good hunting!
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 06-20-2002, 09:10 AM
Tony,
Thanks for the encouragement here. This car will not beat me after everything I've gone through with it. I haven't driven it in over a year due to a calamity of errors, very long story.
The airflow meter did get a coating of oil and I did clean it out thoughly. The door does move freely and comes back to close on it's own. I haven't tested it with a meter yet.
Dan O
Old 06-20-2002, 09:22 AM
