Plastilube
i searched and read about plastilube and i could not get a definitive answer.
should i use it to coat the bore of 1972 m calipers and the seal on the piston if not should i use the dow 111 that warren recommended
1975 911S Targa Silver Anniversary Edition |
I went to a lot of effort to get the Plastilube. After all was said and done, I'm not sure it was worth it, many say just lube with brake fluid. My pistons don't retract very well, so I wondering if the Plastilube it too stiff or not allowing the seal to grip the pistons to pull them back.
Sold: 1989 3.2 coupe, 112k miles |
AutoBahned
a search will show the benefit of using the magic Porsche brake "grease"
thanks i did the search
I searched for plastilube
none of the post were definitive. warren suggested the dow 111
AutoBahned
I used Plastilube during my brake rebuild three years ago and have had no issues with my brakes.
1969 911T - The "Rat" 1997 A4 Quattro 2.8 (270k) - Black Kaniget - Dead but not forgotten 2010 Jetta TDI Sportwagen - Egg Butt (also Spewing Dragon) 2001 Eurovan Weekender - Bruni |
thanks for the note
thank you for the information, that is a definitive yes answer i was looking for.
