-   -   New Renn Shift Install Question (http://forums.pelicanparts.com/porsche-911-technical-forum/720379-new-renn-shift-install-question.html)
macssc911 11-29-2012 03:14 PM
Fellow Pelicans, I just received my new shifter and from all I have read this is easy, so far seems that way, pulled old unit out followed Jwest instructions. Went to stick new unit in the hole dropped in. Their instructions say at that point bolt up 6mm bolts to bracket and make sure spacer plate is still attached, it was,so now the new units sits in the hole higher on the back than the front because of the spacer and the 8mm bolts that came with unit are not long enough for the rear plate mount. This all seems strange, sure I must be over looking something simple. 82 SC
Any Help greatly appreciated
Mac
zippy_gg 11-29-2012 03:42 PM
Got pics?
WIL84911 11-29-2012 03:48 PM
I think I encountered the same problem which caused me to reuse the old, longer bolts. I may be wrong.
