1974 911 w/ 83 SC engine
Off topic: Removing Gear Oil Smell?!
Hello all, I don't know if this is the right forum, but I need some help. I accidently washed a rag I used to clean up some Swepco trans oil with a bunch of other clothes, and now EVERYTHING smells like gear oil. You know the smell. It's in my shirts, socks, pants, the whole load. Is there any prescribed method to removing that smell from clothes? Thanks!
Old 11-28-2012, 10:03 AM
Banned
Yeah, but you won't like the options.
1.) Dry clean everything. The solvent will remove the very small amount of gear oil you spread around to all the other clothes.
2.) Wash everything over again, but in hot water for both wash and rinse, and use double detergent if you can. You can rinse again after, but if you want the smell gone, you have to remove every little bit of the oil.
Neither way is perfect, but dry cleaning will do the trick.
Old 11-28-2012, 10:16 AM
Gear oil smells NICE! You will get used to it and then not even notice anymore!
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 11-28-2012, 10:18 AM
Ewwww. Nasty.
Pinesol. Then wash again. Then add softener. Then hang outside for a week,
Old 11-28-2012, 10:23 AM
Regis turd ab user
Above suggestions are good, hot water wash and dry cleaning. I would wash them again at least once more before dry cleaning with a good degreaser detergent, Wisk is pretty stout or Castrol degreaser or Simple Green. Don't forget to wipe down the inside of the washer after, that kind of crap has a tendency to migrate after the fact.
Old 11-28-2012, 10:27 AM
RETIRED
Joe Bob's Avatar
Wash, dry clean, then throw them away....hate that smell.
2012 ML350 3.0 Turbo Diesel
Old 11-28-2012, 10:37 AM
mmari270's Avatar
Try washing them with a skunk, they'll smell better
Old 11-28-2012, 10:45 AM
Flat Six
Flat Six's Avatar
Here's what I've done; it's worked reasonably well for me:
1) Soak in bucket of hot water w/Dawn dishwashing detergent
2) Rinse in clear water
3) Soak in bucket of hot water w/Oxy Clean
4) Rinse in clear water
5) Toss them in the washer, launder as usual
HTH
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 11-28-2012, 11:28 AM
AutoBahned
RWebb's Avatar
the smell is from sulphur compounds - I dunno what oxidation state they are in or if it is an S tacked onto a long chain or ring organic molecule.
That might help in finding out what exactly to use. You can always try an acid or H2O2 (may bleach your clothes) like with skunk stink, which is also a lov mo. wt. sulphur containing molecule.
der LubeMeister may have some ideas...
Old 11-28-2012, 12:13 PM
Sugar Scoops Rule :)
dave 911's Avatar
It's definitely a unique and stubborn odor...I have a few rags in my rag box that have been washed numerous times and still smell - I just threw one of them away last week....
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 11-30-2012, 05:07 AM
Guardsred911's Avatar
perhaps washing in white vinegar... we use that often in place of bleach and it's pretty good..
J
911 SC - 1980
911 S - 1977
Old 11-30-2012, 05:38 AM
