-   -   How do you measure torque hard brake lines (http://forums.pelicanparts.com/porsche-911-technical-forum/721820-how-do-you-measure-torque-hard-brake-lines.html)
irl 12-03-2012 08:05 AM
I am replacing the entire hard brake line system on a 75. How do you measure the torque on the fittings when it requires a wrench, not a socket.
thanks
KTL 12-03-2012 08:12 AM
Well you could use a 11mm crowsfoot wrench and adjust the torque setting on your inch-pound torque wrench accordingly, by the calculation that includes the center-to-center length of your crowsfoot
Torque Wrench Adapter Extended Calculation - Engineers Edge
mnez 12-03-2012 09:44 AM
You really just need to snug them up tight with the correct line wrench. Don't over do it.
KTL - cool calculator though, for more torque sensitive procedures.
irl 12-03-2012 09:47 AM
Any type of compound on the threads or keep them clean.
mnez 12-03-2012 09:55 AM
Dry is fine. You could put a little never-seize on the line under the nut. That's always the part that seizes up.
KTL 12-03-2012 09:56 AM
Agreed 100% that snug is fine. No gorilla tightening needed.
No need to lube them with anything. Dry is fine.
Bob Kontak 12-03-2012 10:23 AM
snug them up tight
A firm snug. +1
Mrmerlin 12-03-2012 01:24 PM
I second the use of antiseize under the nut where it cinches the line,
this will keep moisture from corroding the line to the nut,
If your working on old calipers and the line nuts are not turning,
use a torch on the nut head and around the caliper area where they are screwed in ,
use PB blaster after its been heated they will usually come out.
