1974 911 w/ 83 SC engine
Performance cam re-grind worth it?
I have an '83 SC motor thats already been punched out to 3.2 liters. Still has CIS. Stock heat exchangers, single in/out muffler. No cat. No O2 sensor. I'm looking--like everyone--for a little more power, and am intrigued by a cam regrind now. From what I understand a 964 profile grind will afford me more low-end torque and more power in the "useful" RPM band for street driving. But I may be looking at faster wear on valvetrain components as such, I've also read.
My question is, seeing what I have and don't have on my motor currently, would a cam regrind be worth the $800-1000 prices I've seen? Is the power difference considerable? What else goes into a cam regrind I am not considering? Will I need to make other changes to feel the full effect of a regrind? Am I better off getting headers and a pre-74 style exhaust for bang-for-the-buck performance? I don't see a lot about cam regrinds here, in fact when I searched the last posting exclusively about the subject looked to be from 2011. But maybe I missed some...
Old 12-05-2012, 08:31 AM
Tired Member
DaddyGlenn's Avatar
Change the exhaust first. Get a nice set of SSI's and a free breathing muffler.
At some point I will probably regrind my cams to a 964 profile and I will have the rockers rebuilt at the same time. I am figuring $1,500 to $2,000 to cover everything and leave room for a couple "while I'm in there" items.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 12-05-2012, 08:46 AM
I would rather be driving
jpnovak's Avatar
1. Change exhaust.
Next, where do you think you need more power? city driving? high rpm?
Many times for a street car it is the throttle response that sucks. In this case. dump the CIS and consider an EFI conversion. The car is so much more driveable. I just converted a car and the next step will be cams. However, the car runs so crisp now that the owner may not want to swap cams for a while.
Just my $0.02.
Old 12-05-2012, 09:49 AM
Spirited street driving. I use the entire RPM band, but would like to see more torque around 3k RPM than 5500RPM. I'd love to swap to EFI but I don't even know where to begin with that process. When I search I can't seem to find an EFI thread that starts at step one. It always, " Help with this EFI swap I've already done..."
So exhaust swap it is. Now...about snapping off exhaust studs
Old 12-05-2012, 10:02 AM
Tired Member
DaddyGlenn's Avatar
Originally Posted by Hotwatermusic View Post
{snip}.....Now...about snapping off exhaust studs
Many, many threads on that subject. Good luck.
Glenn
Old 12-05-2012, 10:43 AM
Tired Member
DaddyGlenn's Avatar
P.S. CIS to EFI conversion and index
Glenn
Old 12-05-2012, 10:52 AM
