-   -   Please identify 1977 Carrera 3.0 timing marks (http://forums.pelicanparts.com/porsche-911-technical-forum/722471-please-identify-1977-carrera-3-0-timing-marks.html)
Bill Jennings 12-05-2012 10:25 PM
Hi,
Can anyone identify what these 4 marks are please.
I cannot see any identifying letters or marks on the face of the pulley.
Billhttp://forums.pelicanparts.com/uploa...1354778555.jpg
T77911S 12-06-2012 03:05 AM
clean off the front of the pulley and see if you can see a Z1 or any numbers. i just pulled my motor and finally saw that my timing mark was 35 degrees.
it can help to line the roto up to the timing mark on the dist if you can see Z1.
Bill Verburg 12-06-2012 03:23 AM
Originally Posted by Bill Jennings (Post 7134342)
Hi,
From left to to right in the pic
the left most 2 notches are
5° ATDC 0(AKA Z1)
the right most 2 notches are
35°BTDC 30° BTDC
edited to correct for mis-remembered crank rotation
Bill Jennings 12-06-2012 03:41 AM
I've already tried to have a good look with a mirror but i'll try some carb cleaner on it.
Bill Jennings 12-06-2012 04:36 AM
Bill,
Many thanks I was reading them the other way round and that didn't make sense.
Any idea why the C3 timing is ATDC and most other 3 litre 911's are BTDC?
Thanks again
Bill
Gib Bosworth 12-06-2012 04:56 AM
What's interesting is that the 74/75 US Carrera spec book shows those marks as (left to right like Bill says) 5 deg ATDC, Z1 for the left pair, and 30 deg, 35 deg. BTDC for the right pair. The spec book for the Carrera 3.0 does not show the pully wheel diagram, and only lists 5 deg. ATDC for idle timing, and no timing number at 4000-6000 rpm. Why would there be timing marks for 30/35 ATDC?
Bill Verburg 12-06-2012 05:48 AM
Originally Posted by Bill Jennings (Post 7134561)
Bill,
Thanks again
Bill
for '976-77 C3,
Idle timing w/ distributor vacuum connected is 5° ATDC
T77911S 12-06-2012 05:51 AM
i was wondering the same thing. wouldnt the 30-35 degree marks be "BTDC"
Bill Verburg 12-06-2012 05:58 AM
to check timing at max advance
earlier models were speced to either 30° or 35° BTDC @6000 rpm
I may have gotten the left/right thing mixed up as I don't really remember which way the crank pulley rotates
if it is rotating clockwise in the pic then the right 2 are 30° 35° BTDC
and the left 2 are 5° ATDC and TDC(Z1)
Bill Verburg 12-06-2012 06:02 AM
I used to put a bit of phosphorescent chalk on the 5° ATDC mark, it would fluoresce under a timing light making it easier to see.
It appears that there is chalk on the left most mark, probably for the same reason
which means that if the pulley is rotating clockwise the far left mark is the 5° ATDC
Gib Bosworth 12-06-2012 06:03 AM
The engine rotates clockwise. Thanks for clearing up your previous comment, Bill, you comments are always on the mark, so I just was puzzled about that earlier comment.
Bill Verburg 12-06-2012 06:10 AM
It's been a looong time since I swapped that engine out
