-   -   How do I make a tunnel brake line. (http://forums.pelicanparts.com/porsche-911-technical-forum/722697-how-do-i-make-tunnel-brake-line.html)
irl 12-07-2012 09:53 AM
Rebuilding complete brake system and I have bought some parts already formed and I am shaping some lines but what and where do I get the material online to make a new tunnel brake line. Did my searches, has anyone researched and found the parts.
thks
86 911 Targa 12-07-2012 10:14 AM
Lines.
thks
If you are looking for a Porsche part,
try our host (Jason) @ 1-888-280-7733 X233.
Good luck,
Gerry
kodioneill 12-07-2012 10:39 AM
You can also get straight brake line at any parts store and bend it yourself.
175K911 12-07-2012 10:53 AM
Just have to be careful with the lines you get. The Germans use an inverted flare so have to get the correct fittings. And much of the stuff at the typical Autozone or Pep Boys use cheap aluminum fittings that strip the first time you try to tighten them so get a proper flare nut wrench to minimize the damage.
I'm in the process of removing several lines I'd installed 2 years ago that I got from Autozone because all the end fittings stripped the first time I tried to take them apart. The original lines still work fine after 25 years, but the crappy replacement lines have stripped after one use in 2 years. So I'm going to find good quality hard lines and do it over.
porsche930dude 12-07-2012 12:02 PM
i always use the old fittings if they are good. you know they fit and are of good quality. unfortunatly the only way to get a good flare is to have a very expensive flare tool like a snap-on
KTL 12-07-2012 02:11 PM
Fedhill has excellent tube nuts and tubing
irl 12-07-2012 02:21 PM
My tub has no center line at all in it so I must fabricate it.
irl 12-07-2012 02:23 PM
Fedhill looks great, just need to get the sizes i need for the lines and nuts
roblav 12-07-2012 04:54 PM
There's always AN3 braided hose then adapt to the calipers...
Two Rivers 12-07-2012 05:15 PM
I looked and our host did not seem to have them. But $toddards has a ten piece set. You might call them.
irl 12-07-2012 08:50 PM
Anyone have the size specs on the nuts
frankc 12-07-2012 09:29 PM
When I was purchasing new brake lines several years ago, all but two of the OEM lines were still available to order (it took several weeks for them to arrive from Germany). For the two NLA lines (one was the tunnel line), I measured the old lines (run fishing line through the old line to measure the length), and ordered the two lines the measured length from Fedhill because they were the only place I could find that carried the proper Cunifer alloy lines.
At that time Fedhill would still flare the ends and install the proper fittings for our cars, but I don't believe they perform that service any longer.
frankc 12-07-2012 09:31 PM
I had purchased the Stoddard set several years ago, but I ended up returning or selling them because they were steel, not Cunifer. Perhaps that has changed by now.
BoxsterGT 12-08-2012 05:35 AM
I have the correct Cohline fittings and the Fedhill alloy brake line in bulk.
Email me for details.
Len at Autosporterngineering dot com
fanaudical 12-08-2012 06:46 AM
Not meaning to hijack, but what do you use for a flaring tool if building these yourself?
