irl irl is online now
irl's Avatar
Send a message via AIM to irl
How do I make a tunnel brake line.
Rebuilding complete brake system and I have bought some parts already formed and I am shaping some lines but what and where do I get the material online to make a new tunnel brake line. Did my searches, has anyone researched and found the parts.
thks
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-07-2012, 09:53 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Lines.
thks
If you are looking for a Porsche part,
try our host (Jason) @ 1-888-280-7733 X233.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-07-2012, 10:14 AM
kodioneill's Avatar
You can also get straight brake line at any parts store and bend it yourself.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-07-2012, 10:39 AM
175K911's Avatar
Just have to be careful with the lines you get. The Germans use an inverted flare so have to get the correct fittings. And much of the stuff at the typical Autozone or Pep Boys use cheap aluminum fittings that strip the first time you try to tighten them so get a proper flare nut wrench to minimize the damage.
I'm in the process of removing several lines I'd installed 2 years ago that I got from Autozone because all the end fittings stripped the first time I tried to take them apart. The original lines still work fine after 25 years, but the crappy replacement lines have stripped after one use in 2 years. So I'm going to find good quality hard lines and do it over.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 12-07-2012, 10:53 AM
i always use the old fittings if they are good. you know they fit and are of good quality. unfortunatly the only way to get a good flare is to have a very expensive flare tool like a snap-on
Old 12-07-2012, 12:02 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Fedhill has excellent tube nuts and tubing
Kevin L
'86 Carrera "Larry"
Old 12-07-2012, 02:11 PM
irl's Avatar
My tub has no center line at all in it so I must fabricate it.
79 SC unmolested
25 GTS
Old 12-07-2012, 02:21 PM
irl's Avatar
Fedhill looks great, just need to get the sizes i need for the lines and nuts
79 SC unmolested
25 GTS
Old 12-07-2012, 02:23 PM
There's always AN3 braided hose then adapt to the calipers...
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 12-07-2012, 04:54 PM
Two Rivers's Avatar
I looked and our host did not seem to have them. But $toddards has a ten piece set. You might call them.
Valkyrie
Old 12-07-2012, 05:15 PM
irl's Avatar
Anyone have the size specs on the nuts
Old 12-07-2012, 08:50 PM
frankc's Avatar
When I was purchasing new brake lines several years ago, all but two of the OEM lines were still available to order (it took several weeks for them to arrive from Germany). For the two NLA lines (one was the tunnel line), I measured the old lines (run fishing line through the old line to measure the length), and ordered the two lines the measured length from Fedhill because they were the only place I could find that carried the proper Cunifer alloy lines.
At that time Fedhill would still flare the ends and install the proper fittings for our cars, but I don't believe they perform that service any longer.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 12-07-2012, 09:29 PM
frankc's Avatar
I had purchased the Stoddard set several years ago, but I ended up returning or selling them because they were steel, not Cunifer. Perhaps that has changed by now.
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 12-07-2012, 09:31 PM
BoxsterGT's Avatar
Porsche Crest
I have the correct Cohline fittings and the Fedhill alloy brake line in bulk.
Email me for details.
Len at Autosporterngineering dot com
Old 12-08-2012, 05:35 AM
Not meaning to hijack, but what do you use for a flaring tool if building these yourself?
Old 12-08-2012, 06:46 AM
