> On the 3.2 Carrera, the difference in output between 91 vs 93 programming > is > about 3-4 hp from 4500 rpm up, because the 93 programming allow about 2 > degrees more ignition timing advance. The low and mid rpm torque and > throttle response gains between the two chips below this rpm are virtually > the same. > > With chipping, you can always run fuel equal or greater octane than a chip > is rated for. In other words running 93 with a 91 chip is absolutely > fine. > But with the 93 chip, you should always be using 93 or greater octane, not > 91. > > Under your circumstances, with 93/94 available everywhere, going with a 93 > programming is a good option. The problem is 2/3rds of the USA only gets > 91oct at best. Let me know if you have any other questions. > > Regards, > Steve Wong |
| All times are GMT -8. The time now is 11:48 AM. |
