irl irl is offline
irl's Avatar
Send a message via AIM to irl
Center fill tank images?
When looking around I see many posts and pictures on center fill tanks and hoods but does anyone have a good set of images, instructions, materials and part suppliers on how to do this.
Thanks,
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 08-18-2010, 08:52 PM
sent you an e mail
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 08-18-2010, 10:35 PM
East Coast R Gruppe
mike monde's Avatar
Dave from TRE is who I would want to talk to. From what I have read and seen, he is the best around.
OGRP3
RGRPNE
Old 08-19-2010, 03:22 AM
These are based on using a reproduction cis tank (74-89) that fits all years 1965-1989. We can do it to a repro early tank, but the tube gets squashed down where it is welded to the tank. There is not enough room as the tank is so skinny there
This is also what we offer if you have a competent weldor to install on your existing tank
1970 911 Targa "ST"
Old 08-19-2010, 08:49 AM
I can help you with this kit
true the hood filar kit - Early 911S Registry Bulletin Board
Regards
Marek
Old 08-19-2010, 10:39 AM
If someone was to do this to a SC, they probably shave the door on the fender, what would you do for windshield washer?
is there a neat solution to this?
Old 08-19-2010, 11:51 AM
maresdesign's Avatar
I sourced a old 50's VW tank and cut off the neck, bought a new 100mm cap, had a friend that could weld. You get the picture.
Here's my build thread:
Cutting up my early 911 - project speedster cont.
Old 08-19-2010, 08:03 PM
Mr9146's Avatar
Ask yourself this question - why does the filler have to go in the center of the hood?
Here're a few we just did on a customer's car ... all steel, hand fabricated trough, hand-rolled lip on the hood with wire inside the roll-over ... purchased reciever for cap from Dave @ TRE:
Old 08-19-2010, 09:37 PM
irl irl is offline
irl's Avatar
Dave,
Im backdating a 74. Because I'm on the East Coast, I can't see trying to ship a entire finished repro tank so could you send me a cost on a finished neck and the hood ring. I do have a question though. Alignment is critical, Im assuming you cut the hood hole first?, how do you get an exact neck placement. Im guessing using welding magnet right angles to hold the neck in place while you adjust???
79 SC unmolested
25 GTS
Old 08-20-2010, 06:36 AM
Hotrod911T's Avatar
Ed,
I installed a center-fill fuel tank and filler setup from TRE in my '69 911. Dave told me to install the tank, put a thick layer of grease on the rim of the filler tube, lower the hood, and then the location of the filler tube is located on the underside of the hood. I installed the fiberglass drain under the hood and cut the hole in the hood as the last part of the install.
Rod
Old 08-20-2010, 08:23 AM
Originally Posted by Hotrod911T View Post
[/CENTER]
that looks awesome!!!
Old 08-20-2010, 12:50 PM
irl irl is offline
irl's Avatar
Marco how is the bead constructed on the backside of the hood hole.
79 SC unmolested
25 GTS
Old 08-20-2010, 01:02 PM
Mr9146's Avatar
It was hand rolled (pliers and hammer) over a piece of spring steel from a filler-neck boot that was cut to size. Patience and time ...
Old 08-22-2010, 03:13 PM
Arnage
Arnage's Avatar
Good things come around. Ed bought my RSR project I abandoned in favor of an R build and I needed an example of a thru-the-hood filler using a full size spare, early tank............and I finally found it on Ed's thread. Thanks again Ed!
Old 12-12-2012, 10:22 AM
Air Cooled
Craig_D's Avatar
I've been following the recent threads on proper alignment for the center fill, and cutting the hole in the hood...all of the measuring and checking. Then I just read this from Rod (above) and thought, how simple and brilliant!
"I installed a center-fill fuel tank and filler setup from TRE in my '69 911. Dave told me to install the tank, put a thick layer of grease on the rim of the filler tube, lower the hood, and then the location of the filler tube is located on the underside of the hood."
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 12-12-2012, 10:52 AM
irl irl is offline
irl's Avatar
The grease on the rim can no way be exact enough. You could easily be off an 1/8 " or more. I also think its important to cross ref this other thread going on Center-fill hood hole location help
Old 12-12-2012, 11:20 AM
Air Cooled
Craig_D's Avatar
I guess it could depend on how well the filler comes into contact with the hood. If it makes a perfect ring, then I'd think you might be in good shape. It does seem to have worked pretty well on the number 7 car above ^^ (I'm not sure what else he did to make sure it's aligned).
'69 Honda CL350
Old 12-12-2012, 11:46 AM
