Montana 911
I am going to order a front mount oil cooler like the carerra version to replace my trombone...what are the specs I should go by (i.e. FTG Size 6, 8, 10, or 12) and size of the cooler?
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Montana 911
bump.......
Navin Johnson
you would want -12 fittings
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Montana 911
Thanks Tim, I really do appreciate the reply.
Now if anyone can get me the dimensions fo the cooler?
Anoyone with a good supplyer for front coolers?
Tanks
Arnljot 1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband 1989 928GT 1972 BMW 3.0S |
H. D., I would recommend getting one of the complete Carrera oil cooler conversion kits Pelican sells: PEL-EXTOIL-01 or PEL-EXTOILSK if you're thinking about this conversion. They're a chunk of change but you'll get all the bits you need. The fittings on the OEM cooler lines are a German (DIN?) type and are not the same as the AN fittings I believe you are referring to. To convert to AN fittings one needs adapters such as those sold by http://www.batinc.net/ The adapters are not particularly cheap themselves. You do not want to use fittings that have a smaller ID than the OEM oil lines (I recall these to be 19 mm or about 3/4") to avoid creating too much pressure drop and restricting the flow of oil to the cooler. I've helped install one of the Carrera coolers on an SC; it required a long afternoon with the car on a lift. You'll also need the oil line wrenches or a good substitute. Cheers, Jim
Montana 911
Here is where I plan on getting mine.
Navin Johnson
you can get a raditaor type front fender cooler from a number of sources as a kit, the cooler comes with-12 fitting, and two pieces of aeroquip type line with the din and AN fittings
I recall that to really match the OEM oil line ID one needed to use AN-16 hose and fittings. Here's an old thread that may be of some interest:
http://forums.pelicanparts.com/showthread.php?threadid=54833&perpage=20&highlight=AN AND fittings&pagenumber=1 Cheers, Jim |
Montana 911
Jim
The BAT page seems pretty good, and the Kit-B option may be what I go with...thanks for the info. or the kit from this U.S. based business: http://www.racerpartswholesale.com/cooler.htm
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R Last edited by k9handler; 06-26-2002 at 03:52 PM.. |
Yeah Jim, the Bat page had all the info I was looking for. Tanx
k9handler: Tanx for starting this tread. I've had these questions on my mind for some time. Did you read that Porsche Oil Cooling Guide on the Bat page? That pretty much covers it: http://www.batinc.net/files/kits.pdf So now I have a problem. With all the info on Mocal, I'd prefere to shop there, but Setrab is Swedish and since i live in Norway its right next door. Not much info on their home page thou : http://www.setrab.se
Arnljot 1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband 1989 928GT 1972 BMW 3.0S Last edited by aseem; 06-26-2002 at 04:26 PM.. |
Montana 911
no problem Arnljot
I also will be in Europe soon, but before I drive my car across the NM, AZ, and CA area to ship it I need the cooler installed. I am probably going to go with the mocal since it is an entire kit and will be easier to get shipped quickly.
HD,
I have said this before ... but some choose not to listen ... The factory rubber lines to adapt your brass hard lines to the Carrera (or SC or Turbo) cooler are 22 mm ID (as are the rest of the scavenge lines) and almost identical to AN-16 hose ... if you get one of those short $25 lines and remove the swaged ring, the fitting will slip into AN-16 hose perfectly, and a simple worm-gear clamp will hold it in place without leaking. One $25 metric hose produces two adapter lines witrh AN-16 ends AND metric ends! Whether you need straight, 90°, or 135° ends at the cooler depends on which cooler you get! It should be obvious why AN-16 fittings on a cooler are preferred. Going smaller to save money is not a great idea! There is typically no significant difference in price for AN-16 fittings vs AN-12 fittings on a cooler of a given size! it may take a while to find a cooler of the appropriate size equipped with AN-16 fittings, but your scavenge pump will not suffer from extra loading that AN-12 lines and coolers cause! BAT, Ltd. can get AN-16 thermostats and coolers ... that is where I got my AN-16 thermostat!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 06-26-2002 at 06:15 PM.. |
Thanks Warren for reminding us. I just read through that thread from last year on the subject..
Montana 911
Warren...
I guess I am confused, do you have any pics to help me visualize the install? What exactly are the differences in the hose/fittings that you stated? On the positive note, I do have a friend who is very good with cars and has done most of my upgrades with me. I usually research the info, print the results and then purchase and install the upgrades with his assistance.
HD,
If you visualize the hoses in this pic with AN-16 fittings on one end ... that is what I am suggesting.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Montana 911
ok...I think I have it.
I guess I will look a bit closer at the fittings and go from there, but I do understand now how you suggest the mod with clamps.
