Senior Member
Is Bentley correct about this?
In anticipation of putting some cams (similar to the ones used by Superman) in my 3.0 this winter, I'm reading up on 911 cam timing procedure. I have both the Factory and Bentley SC manuals .
Question to you who have a Bentley SC manual.... Is the timing procedure as outlined on pages152-9 to 152-11, correct? Bentley seems to differ somewhat from the Factory book, although I may need to read it more closely.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Senior Member
Doug, the procedure is so simple that I'm not even going to look into the Bentley thing. Before my rebuild, I had read and considered the few descriptions I saw, and came to the belief that this procedure does indeed have an inappropriate reputation. Do not imagine this to be difficult at all. You need a dial indicator and the special holding fixture, which you may borrow from me. You fix the darned DI against the spring retainer and adjust the valve like normal. BTW, this is how I like to adjust the valves even with the engine...especially with the engine in the car. so then you rotate the engine 360 degrees and see what the DI says. If it's not right, you move the crank until it is, remove the sprocket pin, rotate the engine back to TDC and put the pin back in. Rotate the engine 720 degrees and see if it's right. You'll be impressed how simple this is. Getting the rocker shafts out is much harder.
And I wish I could be there to see the smile on your face when you drive the car after this transplant. I'm still wearing mine.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
What cams did you use, Superman? I'm assuming that your engine is still CIS(?)
David Schultz 1973 911T 2.7 |
Author of "101 Projects"
The procedure is well documented in the 101 Projects book too...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Somatic Negative Optimist
Doug: What kind of cams? And, are you going to use rocker shaft seals when re-assembling?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Use the rocker seals - talk about cheap insurance!
-Wayne
Senior Member
I used the fancy 20/21 cams, available from WebCams. AKA 964+ cams. 964 cams work very well too, from what I've heard. And I did use the rocker shaft seals. You'd be silly not to.
Senior Member
Thanks for the info, Jim.
Yes, I will be using the WebCam 20/21 grind. It's just that I probably won't find them for pocket change like you did!
Senior Member
Anything can happen at John Walker's swap meet. Sleepyheads get leftovers. August 10.
