POR15 Parts Cleaner
Has anyone used the POR15 water based parts cleaner? If so, what dilution did you use? The lable says that up to a 10:1 ratio can be used, but I would suspect that would greatly extend cleaning time. Any tips or hints would be appreciated.
Thanks,
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Do you mean Marine Clean? I've used Marine Clean many times. The stuff is powerful. I usually mix 50/50 if I'm cleaning something really dirty.
When I pulled my engine last summer, I used de-greaser in my engine compartment. It made a dent in the stuff when I scrubbed. I then got some Marine Clean, mixed it 50/50, and it was like the parting of the red sea. I used a spray bottle, as recommended, and every time I would spray the engine compartment, where the spray stream hit, you could sea the grease/dirt just push away and the paint showed through. I plan to rip my front trunk apart this winter, clean everything with Marine Clean and then go through the wiring installing one of your awesome fuse panels. |
That's the one.......
Yep, that's the stuff. Right now I think that I have it mixed one part cleaner to 3 parts water. It is in a parts cleaner tank with the pump fed nozzle. Should get the job done! I appreciat the reply.
