-   -   Removing E bake handle (http://forums.pelicanparts.com/porsche-911-technical-forum/724058-removing-e-bake-handle.html)
Mike80911 12-16-2012 09:32 AM
I did a search but could not find the answer. How do you remove the e brake handle from the car? I removed the auto heat cover unit and removed the 3 bolts holding the e brake assembly to the body but cannot get to the cables to remove the unit. How do I disconnect the cables from the assembly?
Mike
Danny_Ocean 12-16-2012 09:55 AM
Here's a start:
http://forums.pelicanparts.com/porsche-911-technical-forum/697328-calling-ebrake-experts.html
http://forums.pelicanparts.com/porsche-911-technical-forum/391973-handbrake-removal.html
78SCRSMAN 12-16-2012 11:10 AM
The easiest way and likely the only way is to undo the e-brake cables and heater box cables from underneath the car... e-brake cable attachment is behind the rotors, remove the nut and you'll have all the slack you need.
