-   -   HI-Beams continually ON(when turning lights on)...83 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/724117-hi-beams-continually-when-turning-lights-83-911-a.html)
Tilikum Turbo 12-16-2012 02:55 PM
Does anyone know of an additional relay/switch between the fuse box(Black 5-prong relay) and the steering wheel actuator/stalk for turning on the high beams?
Relay at fuse-box checks out OK, and actuator/stalk contact is not fused together.
Reading the Bently Manual, its described as a 4-pole Headlight Dimmer/Flasher Switch(which is NOT the 3-pole ON-OFF Push-Pull/parking light/headlight Switch)
Thanks for any help!;)
Bob Kontak 12-16-2012 03:28 PM
Check post #3.
http://forums.pelicanparts.com/porsche-911-technical-forum/691255-turn-signal-fuse-blowing.html
Crude Rudy 12-16-2012 03:33 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
this should fix it
DRACO A5OG 12-16-2012 03:53 PM
Search under WON, he posted the fix and others contributed other things they found :D
dshepp806 12-16-2012 04:52 PM
Great threads on this. Has certainly bought me time....
BEST!
Doyle
