Tires on a 82SC
Hi guys,
Need your help here.
3 month ago I changes my old tires to Toyo R1R on my 911.
I have problem that my steering wheel is shaking between 65-75 mph.
With the old ones there wasn't any shaking.
I try to calibrate the wheels with 3 shops. still shaking.
I'm thinking about changing the tires to a better ones.
What would you recommend me.
Yaron
1982 Black 911sc coupe
2000 Boxster S
2007 Harley Davidson Night Train (very customized)
1971 conv' beetle, 2332cc (sold )
Old 12-15-2012, 11:17 PM
Daviboy's Avatar
Check ball joints, A arm and torsion bar bushings and get re- alignment done probably nothing to do with tyres
Old 12-16-2012, 12:19 AM
RETIRED
Joe Bob's Avatar
How much weight did they use on the balancing? Have they tried to balance them while ON the car? Have you ruled out issues with your front suspension?
Could be loose balljoints, sway bar, T-bar, shocks etc.....
2012 ML350 3.0 Turbo Diesel
Hell Belcho
Nostril Cheese's Avatar
could be water inside the wheel or possibly a broken belt in the tire too.
Old 12-16-2012, 12:28 AM
Hi, I put R1Rs on my 82. They are 205 / 225 on 6 & 7 x 15" Fuchs. Have had no problems with balancing. Look into other areas, such as bearings and balljoints, as sometimes changing to tires with more grip unveils hidden problems.
Old 12-16-2012, 12:59 AM
Thanks guys. I'll check other parts on the car and see what is the problem.
Any simple way to do it?
2000 Boxster S
Old 12-16-2012, 09:48 AM
RETIRED
Joe Bob's Avatar
Put it up on a rack and start wiggling stuff.....spin up the wheels and look for wobbles....
Old 12-16-2012, 09:50 AM
I will do so. Thanks
2000 Boxster S
Old 12-16-2012, 08:36 PM
OK.
I got turbo tie rods+ Elephant Racing sway bar bushing and A arm bushings. what do I need more for this job? al these parts a seating in my garage for 2 month. it's about time to make it happen
2000 Boxster S
Old 12-16-2012, 09:08 PM
slodave's Avatar
Did you find the source of the problem or are you just throwing money and parts at it? Really hard to tell you what else to get, without knowing the diagnosis of the problem.
Old 12-17-2012, 12:18 AM
Symptoms like this are typically a bent wheel rim.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 12-17-2012, 06:11 AM
Porchcar guy's Avatar
When they were mounted and balanced...did the shop use a road force system ?...This system works much better than the old style balanceing systems
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 12-17-2012, 10:55 AM
Hi slodave, it's not called throwing money it called upgrading bought these parts anyway for upgrading the front. thinking of while I'm in there if something else needed for this job and on the way to fix this problem.
Porchcar guy,
They test and balanced and did it with the best system, not an old machine. it got to the balance of 0 grams.
2000 Boxster S
Old 12-17-2012, 11:20 PM
slodave's Avatar
I'm glad you are calling it "upgrading". I just still wonder if you found the problem.
I think I may have given an idea in the wrong tire thread. Since you seem to have shaking through the steering wheel.... With the car stationary, can you turn or move the steering wheel up and down, do you notice any abnormal movement in the steering wheel? There's a bushing that wears out. Maybe it has and the new tires are amplifying the problem.
Old 12-18-2012, 01:30 AM
I changed the bushings 2 month ago so this is not the problem
2000 Boxster S
Old 12-18-2012, 04:31 AM
