serpico007's Avatar
Question What is the cover behind the engine?
I'm trying to figure out what this cover is called. It's located behind the engine up against the back seat. I assume it's to help protect extra heat coming into the rear of the car.
Mine is the original and it's falling apart. How complicated is it to install a new part behind there? Is there a new design nowadays or still the old foam style that I should look for to replace this?
I'm planning on vacuuming every bit that falls off the original as I remove it. It just melts over my hands as I touch it, seriously. It's like tiny beads of foam.
The car isn't running and I'm getting it back to driving condition. So it's not a hazard at the moment to repair.
Thanks.
1976 Porsche 911 Turbo
2017 Land Rover Discovery Sport
Old 12-17-2012, 06:57 PM
Danny_Ocean's Avatar
Heat pad, sound pad, etc. There are hundreds of threads on this subject:
Installing engine sound pad in early 911
Old 12-17-2012, 07:04 PM
serpico007's Avatar
Thank you I had no idea what it was called and got stuck searching different terms!
Old 12-17-2012, 07:22 PM
Banned but not out, yet..
RSBob's Avatar
I would not call it a maxi-pad regardless of size or sound absorbency.
Old 12-17-2012, 07:33 PM
