identify trim piece...
hi, can anyone tell me the part number or correct name of the trim piece in the photo below?
thanks also, does anybody understand the following vanity plate... "DAS IXXI"
1987 Carrera Targa |
Student of the obvious
Trim - ?
Das IXXI = The 911 |
i wanted to get this custom plate. my wife says that nobody will understand the plate. i said porsche owners will understand, screw the rest. women...
I understood it, too.
But are you sure you want to give it a neutral gender?
Bob '82 911SC Targa |
what do you mean?
das = neutral
Der = male Die = female All the same word with different meanings regarding gender.
76 911 S White with maroon interior. |
Masculine -- "der"
Feminine -- "die" Neuter -- "das" I have no clue which form of "the" the Germans would use to describe their car. However, if you used, "Die IXXI", I image quite a few Americans may ask why you want to kill poor ixxi?!
Zuerchers,
The trim piece is called a "cap", the number is 911 555 422 00 and the color code for black is 01c GeorgeK |
thanks for the help, its appreciated.
1.367m later
Gender tip
If I'm not mistaken the correct gender for an automobile would be masculine. "Der1XX1"
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
RETIRED
Ok,,,,,
Explain the movie "Das Boot" Or in the German Navy is a sub a nueter? |
Yup.
Now guess what "Madchen" (girl) is. Mark Twain did a great story on German: http://www.crossmyt.com/hc/linghebr/awfgrmlg.html |
heres a link to a german to english translater. you have to select "german to english" from the drop down menu. it states that "the car" is "das auto" in german.
http://www.freetranslation.com/
Thanks, Tim Polzin, for that Mark Twain link... my German colleague Adde and myself are still wiping the tears out of our eyes!
Belgik 1988 Carrera 3.2L |
Even though "auto" is neuter, Porsche is a proper noun, so the rules change.
Example: Der Porsche 911 Die Porsche 911 Story Go with whatever you think sounds good, but I think most Americans will understand "der" or "das".
i ended up getting the firefighter plates. they only allow for 6 characters so i went with "my ixxi"
Vielen Dank für alle Ihre Hilfe mit der Übersetzung.
911 + 129 = JOB
Does removing that trim plate give you access under the black plastic piece that runs along the top of the door?
I was asking about this yesterday as my Drivers side door lock is not flashing red and they said a wire attaches under the openning on that black trim piece.
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
once you remove the trim "cap" you will find two screws. you really dont have access to anything at that point. you need to remove those screws, then pry off the concealing plug at the rear of the trim panel and remove the screw found behind that plug. then you can remove the trim panel by lifting up and over door lock pin. it takes about 2 minutes and you should have all the access you need to find the wire.
