1973 911T MFI died and won't start
Hello All,
Been a long time since I last posted, thankfully the car has been running ok when I would drive it.
Took it out of the garage today after sitting for about 2 months and drove it around the block a couple times. I noticed it was bogging down a bit and backfiring.
Pulled onto my block and the car just died. I put it in 2nd, hit the gas, and the whole engine cut out and died.
I tried restarting and it turns over, but never catches. I thought it was gas, but I filled it with 2.5 gallons and that registered on the gauge. I can hear the fuel pump when I put the ignition into ON, so I think that's ok.
I haven't done the "fire/fuel/air" test fully yet, thought I'd see if there was something common to look out for.
Thanks for any help!
Old 12-19-2012, 01:51 PM
Bandwidth AbUser
Jim Richards's Avatar
I'd look at the coil or the points as being your likely culprits.
Jim R.
Old 12-19-2012, 01:59 PM
Thanks Jim,
Can distributors just go bad like that?
Old 12-19-2012, 02:14 PM
Start with the points as mentioned. That is the weakest point that can die quickly and suddenly.
I put pertronix in mine to get away from this type of thing and it has been great for many years.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 12-19-2012, 02:32 PM
Bandwidth AbUser
I put in a Pertronix, too. Points can go bad, coils can fail. I had both happen on my old 73E.
Jim R.
Old 12-19-2012, 03:46 PM
kwikt 911's Avatar
Check to make sure your mfi drive belt didn't snap. Do you hear the high pitch whine from the cdi box?
Old 12-19-2012, 04:02 PM
