deshetlr's Avatar
Porsche "strap" or "plastic block"
Can anyone explain the purpose of these and if they can be replaced without pulling the motor? The part number for item #12 is 911-504-930.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 12-19-2012, 12:40 PM
Banned
Here you go:
Do you guy's know what these are?
Old 12-19-2012, 01:13 PM
deshetlr's Avatar
Thanks. My search found nothing. These are quite helpful. The threads do not address installation of factory material with the motor in place. Can I push them in from the bottom? the top? Or does it require pulling out the motor?
Scott
Old 12-19-2012, 01:37 PM
Brown747's Avatar
I tried black foam pipe insulation from Home Depot as a replacement....filled the gaps nicely but melted within 5 minutes of firing the car up!!
1978 SC coupe #1834
Old 12-19-2012, 02:06 PM
deshetlr's Avatar
I'll stick with factory OEM. The Porsche Engineers probably tried the same thing.
Scott
Old 12-19-2012, 02:13 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Très Très Expansive IIRC and mine still remains in the drawer...
Who Will Live... Will See
Old 12-19-2012, 02:46 PM
my take on purpose; to prevent warm or hot air from below engine from being pulled back into engine bay by the cooling fan.....same purpose as sheetmetal & seals that surround the engine.
Secondary benefit is a cleaner top-side of engine.
You can replace them with engine in car, but it's much easier with engine out. The foam blocks are soft enough to compress to manuever into position and then they will expand to fill the available space. They are tougher than they appear....especially compared to blocks that have been in the car for 30 years.
Old 12-20-2012, 03:50 AM
deshetlr's Avatar
Thanks pd. I will add them to my winter project list.
Scott
Old 12-20-2012, 05:17 AM
Mo money = mo parts
I replaced the vacuum hose along the rear firewall last winter and know my foam is in bad condition. The parts manual indicates 911 504 930 has 2 per car. $23.50 x 2 = $47.00 for two pieces of authentic german TUV approved foam, gotta love that Porsche tax.
Grainger has 2"x 12"x 12" has a polyurethane open cell foam sheet for $10 that is rated to 180 F. I know it gets hot in there, but would guess that is high enough since it only touches the body. As long as you aren't hung up on laser cut edges, this seems like the way to go.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 12-20-2012, 09:56 AM
