Here's an easy one
1970 T with Zeniths. Do you test the fuel pressure with the car running or simply with the fuel pump activated ? Thanks
Old 12-20-2012, 10:51 AM
RETIRED
Joe Bob's Avatar
Inline gauge or regulator....
2012 ML350 3.0 Turbo Diesel
D911SC's Avatar
I can check mine on the inline regulator/gauge with just the fuel pump activated.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 12-20-2012, 10:58 AM
I just put in a regulator. Adjusted it to 3.5 with pump activated using an inline gauge. I'm not sure if the pressure will change with the car running.
Old 12-20-2012, 11:48 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If the pump gives out the correct volume...then the pressure should remain the same.
If the pump is undersized or on the way out...then the pressure will drop.
In any case...reving the engine and observing the resulting pressure will tell you the condition of the pump...or hoses (old hoses swell on the inside restricting flow).
Bob
Bob Hutson
Old 12-20-2012, 01:06 PM
