-   -   A/C evaporator blower relay part number (http://forums.pelicanparts.com/porsche-911-technical-forum/7248-c-evaporator-blower-relay-part-number.html)
83SC in PA 08-16-2001 02:06 PM
I finally diagnosed the cause of the short in my A/C system but the local import parts shops can't find me the part I need. It's the evaporator blower relay located in the 'smuggler's box' in the front trunk. Mine has a part number of SR9826 and is says 12volts max 30Amp underneath. The opposite site has a schematic on it. It is a 5 pin relay. Can any of you guys find me a different part number that the parts counter guys will be able to use. Very much appreciated.
rstoll 08-16-2001 03:25 PM
Take the relay into the parts counter and ask the guy to cross it in his Bosch relay book.
Robert Stoll
83 SC
83 944
83 sc euro cab 08-16-2001 04:52 PM
83sc in PA,
I have a 83sc euro. Here's the info on my A/C relay. This is in the slot I inside the trunk above all the fuses. This could be the relay you need:
21131 - 12 Volt
911.615.109.01
This is a 5 pin relay for the A/C, I dont know if this is for the blower specificallly though or if there is another relay JUST for the blower.
plain fan 08-16-2001 09:10 PM
I recently bought this same part from Automotion:
Their part #:910953 $13.95, nice relay, contains an integrated fuse that blows before your relay melts.
plain fan
83SC in PA 08-17-2001 10:09 AM
Thanks to all for your help. I'm back in business and enjoying a cool cabin once again.
Ed
Roland Kunz 08-17-2001 11:17 AM
Hello
Mostly Porsche uses the round relays. The good thing on them is that you can interchange them ( fool proof ) blind under bad situations where time matters ( race, rally, marriage )
Special relays are mostly in the square boxes.
Now also the square box relays have interchangeibilitys but they can´t be used as logig relays like the round ones.
This relay is a "standard" Bosch "Einbaurelais" with a lash to bolt it on a screw. Those relays where also used by many other Car brands and made by other companys. Say your NAPA will have similar things made in taiwan and in a plastic housing. The tin caped Bosch relays are extreem solid state and will switch even under hard loads. The heat will disapier trough the bolt ( Just an other cool coolar ).
This relay will switch the power for the AC and cut it out while starting. The round relay is only for the condensor fan.
Grüsse
[This message has been edited by Roland Kunz (edited 08-17-2001).]
