Difference in rear brake hoses??
Can I use this for my '87 Carrera??
901-355-631-01-M4 = OEM Rubber Brake Hose, rear (sold per each), 911/911 Turbo (1974-83) instead of this.... 911-355-087-00-M4 = OEM Rubber Brake Hose, rear (sold per each), 911/911 Turbo (1984-89) The 84-89 is out of stock with our host. Curious if there is any real difference between these. (Plus, they are cheaper!)
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
They should work. The newer ones have a spring type protector around the hose. I believe they are the same length. You could also go with the stainless steel hoses if you want.
69 911 2.3Ez 85 928S |
