Recreational Mechanic
Luggage compartment front trunk light switch help
The hole on the hood hinge where my front trunk light switch mounts is stripped out. The switch is therefore loose and does not keep a good ground so keeps blowing fuses.
I need some ideas on how to repair it so the switch will hold tightly and ground out properly. I thought of putting a nut on the inside of it, but the thread on the switch appears to be a wierd size, about half way between M8 and M10 and don't match anything standard either. Also thought of using conductive epoxy....but $35 for 0.5oz of the stuff is crazy! Any other ideas on how I can get this thing secure and conductive? Anything conductive I could wrap around the threads to increase the diameter slightly? Thanks!!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing Last edited by Nickshu; 12-24-2012 at 12:23 PM.. |
Drill a new hole next to it?
Paul '87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff. '96 993 cab (gone, oops); '82 SC (gone) |
As the switch is threaded, can you not use spacers and packers to tighten the switch so it is secure, the right height and earthed?
I was able to get it secured by putting a push-nut on the inner aspect of the hood hinge, holding it down with needle nose pliers and threading the new switch into it. I used a nylon washer as a spacer.
I also installed a secondary switch so that the light can be turned off when I need to leave the hood up for long periods of time w/ the battery connected, such as when working on the car. Photo below. Thanks!!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
damn, that's a clean hood
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Thanks! Amazing what stripping and painting will do.
![]() Wish I would have stripped the inside of the luggage compartment. I painted most of the removable panels off the car, paint inside the luggage compartment is noticibly more yellow.
